Build Thread 63 SWC Resto-Mod Roadster Shop Chassis
#41
Post Clear, color sanding and buffing left
Joe Inama (04-17-2017)
j_66chevelle (04-17-2017)
j_66chevelle (04-18-2017)
#46
Well there were many colors thrown around at first but I never could find a modern dark blue that was not full of metallic. A modern color I felt was critical to repairs an longevity as I drive all my cars. Believe it or not from a painters point of view black is easier than silver to repair
#47
The car is stunning! The chassis looks like it could work in a Hummer. 350 hrs in body work plus another 40 for wet sand and buff, holy black Corvette bat man, there's a bill there. I contacted you about the soda blasting. I decided to give it a go myself as I was concerned about who would be doing it and how good a job they would do. I'm very happy with the results so far, I still have the trunk and the bottom to do. I entend to get all the major glass work done then do either a gel coat or a epoxy prime before body filler. It's already been said many times but once more cant hurt, yours is beautiful. I hope you enjoy it many many years.
j_66chevelle (04-19-2017)
#48
looks awesome and love the roadster shop chassis. Not knowing all the details the time spent on your bodywork is not out of line. I know there are many guys on this forum that understand what it takes to do a fiberglass car and it is time consuming. Much more difficult than metal and a heck of a lot more temperamental if not done properly. Looking forward to seeing this come together.
#49
very nice!
j_66chevelle (04-20-2017)
#50
Everything is in Clear now
#51
Painfully Slow Progress - but getting closer
Doors Polished, body a little ways to go
Doors back on body wet sanded and polished
#54
Prep for Stone Guard
Primarily used on European cars lower sections
Has a slight semi gloss finish that resist dirt and stays clean
#57
Final Polish pick up Friday
the line are so sharp you will cut yourself
#58
Body finally meets the frame
well it's been 9 month's of waiting (hell) but they are back together
Final buff prior to mating
stone guard pretty neat stuff
very durable surface
dei insulation in the tunnel
only thing I'm supposed to use on the body for the first year<br/>
engine compartment paint
#60
Rear mounted Battery
Heat shield installed on main computer harness, a little too close to the header
Sway bars arms drilled and powder coated
Clutch Hard Line Bent and installed
Rad over flow and catch can installed Passenger inner fenderwell
