Build Thread 63 SWC Resto-Mod Roadster Shop Chassis
#81
I guess every build should expect some set backs. After getting the exhaust and wheels wrapped up started driving around the neighborhood and noticed some shrink on the passenger front fender. I was expecting to bring it back to Painter to wrap up some other issues with headlights as well as doors however not this soon. I decided I did not want to wait, I was right but I wish I was wrong
ong.
After coloring sanding the issue was still there so the sanding begins
After digging deeper on my new paint job he found an earlier repair that was bonded with bondo his guy missed
now correctly repaired
then primed
sanding
Cover everything to coat the engine compartment with some coating to protect over spray<br/>
Needed to color sand the entire front end
Only the front fender need more black
Clear
more clear
Polish
more polish
We decided to removed the inner lip of the bonding strip so if the tires contact they won't grab anything
finishing up the exhaust panel
ong.
then primed
sanding
Clear
more clear
Polish
more polish
#83
Interior Begins
After working out a number of kinks (installing the windshield 2 times), 6 speed shifter,mechanical speedo, road sand blasting we finally got around to the dash. Brought it to my guy to recover the dash in BMW flat black leather with white contrast stitching which will be the theme for the whole interior, I'm very happy with the results. With the raised tunnel due to the 6 speed the dash is custom, the ac ducts are custom, vintage air mini gen II was needed, custom everything custom. Had to send the clock back, worked with Tremec on the shifter which continues to leak, optima Battery died, Summit sent a new one no questions etc, etc. The MOMO wheel may be a bit small so looking for options
#85
Beautiful car, I love the interior, very well done!
Rob
Rob
j_66chevelle (09-25-2018)
#86
Wow, love the interior! I agree with you, the Momo wheel looks great, but I wish it was available in at least a 15” diameter.
#87
2019 Corvette of the Year Winner
St. Jude Donor '15
very nice....certainly a labor of love and continuous hits on the wallet!
What are you doing with the hood pie pans? Anything custom or stock?
#88
The theme has always been keeping it as stock looking as possible, hood will be stock. I chromed the cookie sheets for durability, taped and painted the centers SEM trim black
firstgear (09-26-2018)
#90
I wanted the car to have slight rake rear to front however the body lines and the front fenders really through it off. Additionally, the Roadster Shop chassis is not adjustable beyond a certain point. We ended up at 1\2 positive in the rear, the only way to get more is to lower it which I don't want to do.
In the front I'm about .5 negative on camber and 5.5 on caster
#91
St. Jude Donor '15
#92
Interior update: Had to wait 2 months to get in the shop and then another to get started, that said really pleased with the end product, getting closer. All BMW leather, headliner will be alacantra in black. Mercedes cut pile carpeting.
One piece headliner
A little dusty but loved the fit
One piece headliner
j_66chevelle (03-15-2019)
#94
At last, interior done, 6 months I guess it part of the journey. I have owned the car for 6 years and it has been in someone else's shop for 2 years. That said very pleased with the final product. See Elegance Auto Interiors in Upland CA
ct
ct
wolfman64 (07-06-2019)
#95
Dang....super job!
j_66chevelle (07-06-2019)
#96
That is one fine looking interior!
j_66chevelle (01-22-2020)
#99
Looks like it’s for sale, what a beautiful car
https://rover.ebay.com/rover/0/0/0?m...2F223859247320
