This topic always generates lots of responses, some heated.
In my area, 92 octane non-ethanol is available. I use it in both my C1s and my C4. I tried using the 87 with ethanol and I could notice the difference especially in the C1s in regard to idling and performance. Perhaps the 92 octane is not necessary in any of them but the absence of ethanol did make a difference in my case. I know many others on this forum experience no problems with ethanol.
Pick the lowest grade it runs on, without pinging. Some people insist on running premium, but you're really just wasting money, if your go runs fine on regular or mid-grade.
Here is California, we can't get non-ethanol gas... and 91 is the highest octane available.
I have an 11:1 LT-1.. Even with the 91 I have to pull the timing a few degrees to stop the pinging.
But I agree with previous posters.. if it's not pinging on regular, premium is a waste of money.
Run the lowest octane you can without pinging. The higher the octane, the slower the burn, and the less energy. Lower octane gas burns faster and produces more energy. You will actually lose performance with higher octane than necessary. In California, where I am, the 91 octane ethanol gas barely does the job with most of my cars.
past 8 years. I am partial to using Chevron brand gas when available.
You can't be assured you are getting Chevron gas at a Chevron station. The majors trade out to save shipping cost. You will likely get the gas from the closest refinery at any station. I buy Exxon or Mobil since I get an employee discount.
[QUOTE=SDVette;1590083752]Here is California, we can't get non-ethanol gas... and 91 is the highest octane available.
Not to mention our wonderful summer and winter "blends".
The higher the octane, the harder the fuel is to ignite, but the burn rate and BTUs produced are the same.
Most of the local gas comes from a tank farm run...
by Chevron and the Union Pacific Railroad. It also supplies aviation jet fuel by pipeline to the Navy's Fallon Naval Air Station where Top Gun Pilots are trained.
I believe all gas is the same. It's the additives each manufacture puts in them somewhere along the line, I don't know exactly at what point though. By the way, Costco is top tier gas, something I just found out.
All comes from the same refineries and the companies just add their own mystery ingredients.
I believe all top tier means is that the gas companies paid to be on that list to put Joe Public at ease and make him sleep better at night that he's putting in "top rated" fuel into his vehicle.
For my vettes, i use Shell though...daily drivers get whatever is closest and cheapest when they need fuel...
Around here, we get gasoline from refineries in Ashland, Ky, southern Illinois and Nashville.
I wouldn't bet all three of them use the same base crude and/or have the same refining processes. Mr Tex in this thread could probably comment on whether that could/would affect the final product, not to mention the specific blends for individual regions.
I can drive a couple of miles and get a different EPA recipe on the gasoline I use.
From: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
i have a friend who used to work for Mobil in gasoline transmission pipeline, and he told me that regular and premium are two separate products as they come down the line, and that they are very conscientious in making the ‘cut’ when moving premium to make sure it is all premium, not regular, or jet fuel, or something else. He said that Mobil adds their ‘secret sauce’ once it is in the big tanks.
I wantd a vette because of the looks and the power they had. When I tune my high comp engines they ALL ping on CA 91 0ctane. So lets de tune it and make it run like a station wagon! Not for me, I like the spunk and sound and the POWER produced with high octane fuel.
Not having the power it was built to have takes all the fun out of it.
Now if your car is just for looks and parades the de tune it and smile.I am lucky and have av gas available, and YES it burns slower and that is the advantage. You can advance the timing to factory specs and get the power it was designed to have.
Back in the day when they ruined gasoline and I couldn't get av gas on a long drive I installed water injection and that took the ping away. Some of my gas equipment that I rarely use has to have the carb taken apart to clean the varnish and corosion out. NO more. I store ALL with av gas and they start after years of no use.
Shelf life seems to be years. I have motorcycles with a mix that were not driven since 2008 and I will start them with a kick start and almost always on the 1st flip after priming. No more taking carbs apart for me, and I enjoy the power that engine was designed for.
