generator key way troubles
Old Aug 12, 2015 | 06:53 PM
wilbur's Avatar
wilbur
Default generator key way troubles
Trying to rebuild my 043 generator. Got it all taken apart but I'm having trouble with removing the key way so I can remove the front plate from the armature.
I'm at the point were the key way is starting to get messed up because of me and a flat top screwdriver.
Old Aug 12, 2015 | 07:11 PM
GTOguy's Avatar
GTOguy
Use penetrating oil, and tap it with a brass hammer. Let it sit overnight. You can take a small drift and lightly tap down on each end...it will rock back and forth and eventually come free. Patience is required!
Old Aug 13, 2015 | 12:28 AM
wilbur's Avatar
wilbur
Ok thanks I'll give it a try....
Old Aug 13, 2015 | 05:39 AM
rich5962's Avatar
rich5962
I always have a can of CRC Freeze-Off for bits like that.
Try it you'll like it. Warning though.....it's smelly, so do it outside over a rag then bring it in on the bench to tap it out. I use a flat ended drift on push each side like a see-saw. They're very soft and prone the expand with other methods.
Old Aug 13, 2015 | 11:31 AM
Ktholin's Avatar
Ktholin
I had the same problem a short while ago. Tried penetrating oil and tapping with punch as suggested. Nothing worked. Finally took it to a shop that specialized in removing broken drills and, using EDM, they were able to get it out. Not cheap ($80), but saved a lot of time and headache. BTW you can get a complete rebuild kit that includes a new key way. The major suppliers didn't have them.
Old Aug 13, 2015 | 12:01 PM
Pilot Dan's Avatar
Pilot Dan
Those key ways can be a pain, they are called Woodruff keys and are readily available at most hardware stores. Use a new one once you get the old one out. If you dress the new one with a flat file, it will come out much easier the next time.
Old Aug 13, 2015 | 12:07 PM
wilbur's Avatar
wilbur
Yep me too...Just got back from the machine shop (I dropped it off).
I tried and tried, frustrated....
Not sure how much they are going to change me.
Old Aug 13, 2015 | 12:16 PM
wilbur's Avatar
wilbur
eBay item number:
271805396702
I was thinking about getting this rebuild kit.??
To generator key way troubles
