Ignition problem
Old Oct 1, 2015 | 12:30 PM
Corvettes by George's Avatar
0Corvettes by George
Former Vendor
Default Ignition problem
Engine was only firing on 3,5 7, (determined by heat gun readings at exhaust manifolds and at exhaust pipes).
Pulled spark plugs, ran compression and leak down check (all good), and checked valve lash (solids---097 Duntov).
Installed new plugs, points, condenser (checked resistance on coil terminals)
Re started engine and now firing on 4,6,8 only.
What--da???
Old Oct 1, 2015 | 12:43 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Wires not properly seated on the cap or plugs. Your cap is junk. That is strange
Old Oct 1, 2015 | 01:34 PM
Former Vendor
Strange, yes.
Loose wires and/or bad cap no.
Going to switch out distributors.
Any other ideas?
Thanks,
G.
Old Oct 1, 2015 | 03:07 PM
Randy G.'s Avatar
Randy G.
Your screen name is 1960FI. Are you running a 1960 with an original FI? If you are running an old points/condensor set up there's very little chance you aren't getting any spark to one side of the engine then it flip flops. I would bet there is a fuel delivery issue.
Old Oct 1, 2015 | 03:14 PM
Tampa Jerry's Avatar
Tampa Jerry
Default Dual points
I know little about C-1 ignition systems, does this dist. have dual points? Are they set correctly? Jerry
Old Oct 1, 2015 | 04:25 PM
Former Vendor
It is a '59 with a '59 unit. Using points/condensor.
Fuel supply is perfect---it is an ignition problem.
Old Oct 1, 2015 | 04:46 PM
ohiovet's Avatar
ohiovet
2016 C1 of Year Finalist
Does the engine actually run on the 3 cylinders?
Old Oct 1, 2015 | 05:10 PM
Former Vendor
This one does.
Really weird sensation putting one's hand at the exhaust outlet pipe and feeling the cold air coming out of the non firing side.
And remember, the side (engine bank) that is firing has flip/flopped from one side to the other.
Also, even though I described the firing as either 3, 5, 7 or 4, 6, 8, the #1 or #2 cylinders do get a bit hotter (maybe 10-15 degrees when their respective side is firing.
As to hear readings from the infra red gun:
Firing side ----- 360 to 450 degrees
Non firing side --100 to 115 degrees
Old Oct 1, 2015 | 05:35 PM
MikeM's Avatar
MikeM
I have to ask why you insist it's an ignition issue? I'm sure you have your reasons.
Old Oct 1, 2015 | 05:47 PM
steve meltzer's Avatar
steve meltzer
Seems like the first thing you'd want to do is to verify that there's spark at every cylinder. I'd use a method other than the IR gun...like pull each wire and make sure there's fire, or use your timing light on each wire to prove there's spark. Obviously, if there is, it's fuel (assuming good compression and third component of the triad of fuel, fire and air is present). steve
Old Oct 1, 2015 | 05:49 PM
Randy G.'s Avatar
Randy G.
I've seen where debris floating around in fuel injection distribution blocks has done the same thing. It covers the line feed to some cylinders cutting off fuel. Then later it moves around and cuts off others. Low fuel pressure can do the same thing, but not likely in this case.
Old Oct 1, 2015 | 07:07 PM
DansYellow66's Avatar
DansYellow66
I was wondering the same thing - and how do you keep it running long enough to figure out which 3 cylinders it's running on?
I'm not sure I can think of a plausible fault in the ignition system that would behave this way. Sounds more like the FI system metering system to me for my 2 worthless cents.
Old Oct 1, 2015 | 07:11 PM
Former Vendor
Another thing that is so weird; it idles at 1200 rpm with no hint of a miss; it will run this way as long as the ignition is on and there is fuel; you'd never think it was running on only three cylinders.l
I have never seen anything like this
Old Oct 1, 2015 | 07:18 PM
MikeM's Avatar
MikeM
I haven't either. See post #9. One time I disconnected the wires on a Dodge V8 just to see how many cylinders it would idle on. It idled on three cylinders but barely. Certainly wasn't 1200 rpm.
Something ain't right here.
Old Oct 1, 2015 | 07:24 PM
Former Vendor
Because the injection unit test flows perfectly.
Have tested flow on non firing cylinders while engine is running.
Again, the firing cylinders have flip flopped from left bank to right bank, and always on rear three cylinders
Old Oct 1, 2015 | 09:07 PM
dplotkin's Avatar
dplotkin
2015 C2 of the Year Finalist
Change your cap and rotor out with a different brand. If that doesn't fix it I'm with some of the others, its fuel, and only FI can account for this behavior unless the cap or rotor is damaged or the distributor is hideously screwed up. I like the plugged FI theory for this one.
Dan
Old Oct 1, 2015 | 11:30 PM
Randy G.'s Avatar
Randy G.
What method did you use to test the flow on individual cylinders? Plugged nozzles can increase the flow to open nozzles and will still show the same GPM.
To Ignition problem
Old Oct 2, 2015 | 05:44 AM
MikeM's Avatar
MikeM
I'm not quite sure how you would do this unless you simply unscrewed the line at the nozzle and observed/measured fuel pressure. That wouldn't mean the fuel was getting through the screen.
You could have developed a huge vacuum leak?
I'd start the engine and squirt some gasoline or flammable mist in the air meter and see if the engine speed picked up and rule out air/fuel issues. I use aerosol non-chlorinated brake fluid for this. It's safer than gasoline.
I don't see how the idle speed can be 1200 rpm either on only three cylinders but life is filled with little mysteries.
Old Oct 2, 2015 | 06:26 AM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
Make sure you check the side play in the dist. shaft. If it's got play it may be only making contact on one side of the cap. Easy check.
Old Oct 2, 2015 | 01:51 PM
GTOguy's Avatar
GTOguy
How about connecting a vacuum gauge? And what about doing a cylinder balance test to verify the dead holes? This is really strange, that the dead holes are changing places....Does it drive at all? Super low power? Or does it drive on all 8 cylinders when you go down the road? I guess what I'm trying to figure out is if the problem is in neutral in the driveway, or actually going down the road.......
