Distributor off 1 tooth?
Old Oct 1, 2015 | 02:48 PM
timmah22's Avatar
timmah22
Default Distributor off 1 tooth?
So the vacuum advance is hitting the shielding/coil and I have no way of advance the timing any more. I have the timing set to 8 dbtdc and it does great there. The book calls for 10 degrees. I'm reading its off 1 tooth and it needs to be rotated 180 degrees. Is that right? Is there a simple procedure taking out the dizzy and put it in correct without going through all the procedures I'm reading from Lars's page? Never removed a distributor. L-79 with pertronix. Thanks
Old Oct 1, 2015 | 03:13 PM
DansYellow66's Avatar
DansYellow66
Actually the usual procedure is to pull the distributor, drive the roll pin out that holds the gear to the shaft bottom, turn the gear 180 degrees on the shaft and re-install the drive pin.
I would first pull the cap and rotate the engine until the rotor is pointing at something you can put a mark or tape on to mark it's position. Also note or mark the relative position of the distributor housing although it will change somewhat after rotating the gear. Then disconnect the wire lead, remove the clamp and bolt and pull the distributor straight up. Note that the rotor will rotate as you pull it up due to the gears. When reinstalling you have to allow for this and start with the rotor rotated so that as it drops in place the rotor will rotate back around to your mark.
You will need to re-time the engine and you are done.
Old Oct 1, 2015 | 03:20 PM
Randy G.'s Avatar
Randy G.
If the vacuum advance can is hitting the shielding but pointing the right direction you are one tooth off, not 180 degrees off so you don't rotate the distributor shaft 180 degrees. That would put your vacuum can 180 degrees around the distributor from where it is now. The easiest way to do it would be to pull the cap, bump the starter around to get the rotor to line up with number one wire on your cap when in place, you may or may not need to disconnect the wires to the distrubutor so you can raise it enough to get it off the cam gear, unclamp the distributor, lift it up, move the rotor counter clockwise or clockwise depending on whether the vacuum can is hitting in front or the back enough to move the shaft one tooth, drop it back down, bump the starter for almost 180 degrees until the distributor drops into the oil pump drive, put the clamp back on lose so you can adjust the timing, hook up your wires, put the cap back on, start it and set the timing. If you are unsure, find a friend to help you.
Least complicated way would be to move all the plug wires one hole left or right if you aren't concerned about the number 1 wire being in the correct location.
GTOguy's Avatar
GTOguy
The first thing to do is to actually verify if the dizzy is off one tooth. You need to find TDC and see where the rotor is actually pointing. And then go from there. If off, you can pull the distributor up slightly after the hold down is removed, and rotate it and re-seat it. Sometimes, you need to turn the oil pump shaft with a long flat blade screwdriver so that the dizzy will seat in the right position. No need to pull the gear off, IMO.
Old Oct 1, 2015 | 03:27 PM
409/409's Avatar
409/409
I had the same problem, but I started the plug wires 1 tower to the left of the window. When I found out you start 1 tower to the right of the window, I rotated all the wires 1 tower clockwise and all is good. Mine is a 427. I don't know if a 327 is the same, but my point is, double check your wiring before you pull the distributor.
Old Oct 1, 2015 | 03:32 PM
Randy G.'s Avatar
Randy G.
There is a notch that looks like someone started to drill a hole near the roll pin hole on the distributor drive gear. That notch is supposed to line up with the rotor. Pulling the pin shouldn't be necessary unless the gear was installed 180 degrees off.
This is an example from an AMC distributor.
Old Oct 1, 2015 | 05:27 PM
Tampa Jerry's Avatar
Tampa Jerry
Default Dist.
There is no need to line up the oil pump with the distributor. Once you are comfortable with where the distributor is to be set, bump the starter and the distributor will fall into place once the oil pump lines up. Now you are ready for your timing light. Jerry
Old Oct 1, 2015 | 05:43 PM
Tooth Doctor's Avatar
Tooth Doctor
Move your spark plug wires on the cap over one terminal.
Old Oct 1, 2015 | 05:49 PM
MikeM's Avatar
MikeM
That is a true statement if the OP has a GM ground camshaft. Not necessarily true if the OP has some aftermarket camshaft.
Old Oct 1, 2015 | 05:50 PM
MikeM's Avatar
MikeM
You are bursting lots of bubbles here. Many here are scared to death to try this.
Old Oct 1, 2015 | 05:54 PM
GTOguy's Avatar
GTOguy
Including myself. Much safer in my experience to simply position the op shaft manually. Easily done and nothing gets sheared or broken. Thanks for the vote of confidence, Mike. BTW, I am running aftermarket cams in 2 out of 3 performance cars. Better safe than sorry, IMO.........
Old Oct 1, 2015 | 05:55 PM
Randy G.'s Avatar
Randy G.
Since he says he's going by the "book" it's a good idea to start with all components set up according to the "book", rather than starting out dismantling instead of adjusting.
Old Oct 1, 2015 | 06:03 PM
Randy G.'s Avatar
Randy G.
Exactly. Chasing the oil pump with a screwdriver is a waste of time.
Old Oct 1, 2015 | 06:08 PM
MikeM's Avatar
MikeM
I don't understand the concerns on these two posts?????????????
The OP said he can't get enough advance, yet his distributor hits the coil and he can't ADVANCE it anymore because of that. That means he's trying to RETARD the timing.
Don't know why he think the distributor is 180* out either. If his cap is wired right, the vacuum nipple is pointing at at the right rear inboard valve cover bolt, he is probably not a tooth off, he is probably off on the distributor gear and half turn. That's why I mentioned the aftermarket cams. It's well known they are not indexed on the distributor gear to the GM print in every case.
I have no idea how many distributors I've installed in a V8 Chevy over the years. Has to be a 100 times. I've never sheared anything nor have I ever had a problem. Never fiddle faddled with that screwdriver deal, it's not necessary but if that's the way you like to do it, it works, just takes longer.
I think the first SBC distributor I dropped was in 1957 and I didn't use a screwdriver then or now.
Old Oct 1, 2015 | 06:36 PM
rongold's Avatar
rongold
From: Putnam Valley, New York. Amateur Radio Operator K2NS
Default Distributor Position
Also true if the distributor happens to have an aftermarket gear. One of my spare TI distributors has a gear with no dimple.
RON
Old Oct 1, 2015 | 07:01 PM
GTOguy's Avatar
GTOguy
I stand by my post #4. Get a baseline, and go from there. Not rocket science.
Old Oct 1, 2015 | 07:03 PM
DansYellow66
I may have made a bad assumption in my #2 post - his mention of rotating the distributor 180 degrees led me to think that he had read up somewhere about the orientation of the distributor gear to the distributor shaft - and he confused the issue of rotating the gear 180 degrees on the shaft to slightly change the rotor orientation and allow advancing the distributor further - with rotating the distributor 180 degrees. I believe this is about the same as a 1/2 tooth change.
Simply pulling the distributor and moving it one tooth is easier and may be a better fix if that much additional rotation is needed.
To Distributor off 1 tooth?
Old Oct 1, 2015 | 07:22 PM
MikeM's Avatar
MikeM
..his mention of rotating the distributor 180 degrees led me to think that he had read up somewhere about the orientation of the distributor gear to the distributor shaft - and he confused the issue of rotating the gear 180 degrees on the shaft to slightly change the rotor orientation and allow advancing the distributor further - with rotating the distributor 180 degrees. I believe this is about the same as a 1/2 tooth change.
That is why I didn't respond at first but he threw me when he said he couldn't advance the distributor because it hit the coil.
Sounds to me like he needs to move the gear but not enough info yet to say that.
Old Oct 1, 2015 | 08:00 PM
chuckaroo's Avatar
chuckaroo
Hi guys
Samething happened me so here's how I fixed. Bring the motor to tdc. Next I take a straight edge and lay it on top of the dist. wires and aligned it through the #1 plug wire and the center coil wire. Standing on my toes I looked down the edge and made a mark straight down on the dist. body. That's the position where the rotor should point at tdc. on compression stroke. Remove the dist. cap and if the rotor points to the rear of the car you need to turn the engine once more 180 degrees. The rotor should point near #1 marked on the dist. body that you made. Look to see if it points before or after that mark. Mine just happened to point slightly before so I needed to turn the dist. body clockwise so it would point dead on the mark. Now carefully and slowly lift the dist. up. The rotor will turn counter clockwise. You will feel it come loose. Not far up maybe 1/2". Now I slowly turned the body clockwise stepping it about 1/64th" at a time. It will drop down over the next gear. With very light downward pressure on the dist. click the starter and the dist. will drop all the way down to the stop. You are changed 1 tooth...no screw driver needed.
Good luck.
Old Oct 1, 2015 | 10:59 PM
66RBS's Avatar
66RBS
To clarify the drive gear has 13 teeth. Moving it one tooth is a 28* swing and the vacuum canister will likely hit the intake runner. Rotate the drive gear 180 deg as described above and you now have a 1/2 tooth 14 * movement. When it is indexed correctly the vacuum canister is not obstructed by the manifold runner or coil bracket AND the tach cable isn't bent unnecessarily.
BTW if your plug wires are indexed correctly the #1 plug wire should be in the first tower clockwise from the window for the points
Randy
