Caster Alignment Help Needed
Old Oct 9, 2015 | 12:00 PM
Mr D.'s Avatar
Mr D.
Originally Posted by ZZtop2
Doing an alignment is not hard, you just need to have a good fundamental understanding and the right tools......and remember to use those tools properly every time, like turntables, doh!
Thanks for all the help guys. Sometimes the solution is so simple you cant see it!
My turntables are two floor tiles and grease under each wheel. Maybe that is my problem not being able to gauge the 20 degrees the alignment calls for.
Old Oct 9, 2015 | 01:07 PM
DansYellow66's Avatar
DansYellow66
Another thought for turntables is if you have a set of car dollies, putting the car up on them during your garage alignment seems to work very well for me. They rotate with the front wheels effortlessly and mine are the crank up type so they are even a bit of help in leveling the car up to work on it.
