I jacked up my 66 convertible in front of the rear wheels. I noticed the gaps on the doors opened up about 1/2 inch on top and the doors would not close. Apparently the back end dropped considerably because of the weight of the differential and rear suspension. Is this normal on convertibles or is it too much. My frame seems to be in good condition but I realize they rust on the inside even though it looks good on the outside. The thickness of metal seems normal on the inside of the keyholes-its not too thin. Any input would be appreciated.
I get about a quarter in change in the rear door gaps on my 66 convertible when I put it up on my lift with blocks on the frame rails in front of the rear wheels and behind the front wheels. I just checked that last weekend.
My rear door gap gets tighter on the ground. My car lived on the west coast most of its life.
It's completely normal especially a convertible, if the car is going to be lifted for a while support the rear a little bit under the suspension or tire with a car ramp then let it down.
A coupe body will actually hold the frame more rigid, the coupe structure is tougher than you think.
My 57 door gap opens about 1/8 to 1/4 inch when I put it up on my 2 post lift.
The flexing does not cause any problems with the paint or door gaps once it is back on the ground.
All convertibles will 'open up' when raised on a lift where their suspension is allowed to hang. (conventional lifts, not 4 post storage lifts). My full-frame all steel '67 GTO does it, my '61 Corvette does it, and every customer ragtop I've raised for the past few decades does it. An open tray is not as rigid as a box with a lid, pure and simple.
Some ugly welding by GM/Chevrolet involving a lot of spot welding. Therefore it flexes, so for any level of real performance """real performance""" it has to get fixed!
A family friend bought a 65 off ebay a few months back and noticed the same thing with his car. Further investigation resulted in a rotted frame at the trailing arm areas on both sides, Swiss cheese.
Needless to say he is now 8 months into a frame off.
