Stp
Old Nov 16, 2015 | 12:22 AM
grumpy10956's Avatar
grumpy10956
Default Stp
hi guys , anyone still using STP ??
or am I the last Dinosaur ??
grumpy
Old Nov 16, 2015 | 12:48 AM
LT1driver's Avatar
LT1driver
never used it and my question is why would anyone?? but to each their own I say.
Old Nov 16, 2015 | 01:06 AM
LouieM's Avatar
LouieM
It's likely you're the last dinosaur.
Old Nov 16, 2015 | 01:37 AM
Gary's '66's Avatar
Gary's '66
They still make that stuff?
Gary
Old Nov 16, 2015 | 09:09 AM
grumpy10956
hi guys , yes they still make it , was reading the various articles on the 1967 loco motion l88 corvette and there low & behold the car had a STP sticker on it, the auto parts store had some in stock , bought a can and put alittle in the oil change for my snow blower .thought I'D ask to see if anyone was using STP in there Vettes, with complaints on oil , a additive might help ??
Old Nov 16, 2015 | 09:15 AM
427/42566 coup's Avatar
427/42566 coup
Haven't used in many a moon. Still have original unopened can
Old Nov 16, 2015 | 09:35 AM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
I use it for assembly lube when I build engines. Works great !
Old Nov 16, 2015 | 09:48 AM
Elba Mike's Avatar
Elba Mike
St. Jude Donor '16
You scored major cool points if you had an STP sticker on your bicycle in the 60's.
Old Nov 16, 2015 | 09:52 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
No doubt!!
JIM
Old Nov 16, 2015 | 10:18 AM
GTOguy's Avatar
GTOguy
What Elba and Hotrod said! I even had them stuck on my dresser!! Still have a can that's so old it says"Paxton Products division of Studebaker" sitting around. Great assembly lube, and helpful when I was driving my worn out flathead six powered '47 Chrysler. Useless in todays engines with today's oils, and pretty much useless in any engine that's not flat worn out.
Old Nov 16, 2015 | 10:45 AM
1955 copper's Avatar
1955 copper
2015 C1 of Year
Remember selling a can of Bardial I think it was called that cleaned Varnish off the engine top end , pumping gas in the 60's , each can had 25 cents in them that you kept . Yes also using STP in my 6 cylinder 1951 Chevy 2 door hard top car.
Old Nov 16, 2015 | 11:30 AM
domenic tallarita's Avatar
domenic tallarita
I did a thread in the NCRS TDB and there were a bunch using it. I still use it for assembly and now they say STP has Zink in it.
Dom
Old Nov 16, 2015 | 11:50 AM
colo63sw's Avatar
colo63sw
Dom
If it has zinc in it, I think I’ll start using it in my un-rebuilt 63 327.
I used it back in the 70’s on ‘tired’ engines, helped smoking a bit, for the next 600 miles or so.
Old Nov 16, 2015 | 11:56 AM
tuxnharley's Avatar
tuxnharley
My understanding is that STP does have high levels of both Zinc and Phosphorous and thus is useful as an additive in older engines with flat tappets, given the low levels in todays oils. The best is actually the red bottle designated for 4 cylinder cars - if you can find it.
Of course, you could also use diesel oil.
Old Nov 16, 2015 | 12:17 PM
LouieM's Avatar
LouieM
It was the same with my Zundapp moped in West Africa in the 1970s. I had an STP sticker on the gas tank and people thought I was Richard Petty.
Old Nov 16, 2015 | 02:02 PM
John BX NY's Avatar
John BX NY
Had a 71 Chevelle years ago with self changing oil. It both leaked and burned it. I would add a can of that mud from time to time to stem the tide temporarily...
Old Nov 16, 2015 | 02:43 PM
vettepoor's Avatar
vettepoor
Active Streak: 90 Days
I tried the stuff in my 65 in the early 70's to slow oil usage. When I tore my engine down for a rebuild I swore I'd never use it again - sticky, nasty stuff, especially when cold.
To Stp
Old Nov 16, 2015 | 03:07 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
I used to run it in my 76 Vega... Kept the smoking down to a minimum!
Old Nov 16, 2015 | 04:26 PM
MikeM's Avatar
MikeM
In 1963, my summer driver was a $100, '58 Biscayne, 283 with a cracked piston. Used a quart of 30W oil every 50 miles and smoked accordingly along with a lot of noise from that cracked piston.
A buddy came up with 4 1/2 quarts of STP so I dumped it in the crankcase. The smoking stopped, the knocking stopped and I used less than a quart of oil/STP the rest of the summer.
I don't really know what other value that stuff has other than to slow down oil burning.
Old Nov 16, 2015 | 04:38 PM
LouieM's Avatar
LouieM
Amazing that your car started at all with that much heavy goo to pump thru the engine.
