1966 weight
What does design weight mean? That figure 3460 is what, small block, big block, + options, no options????? This makes a total of 6 different weights I have found.
This is as bad as figuring engine HP vs RWHP. I guess I have to weigh it.
Shipping weight: As optioned with all normal equipment and full fluids except gasoline, which is factory filled to three gallons.
Curb weight: As above, but with full fuel, which would add about 100 pounds for the additional 17 gallons. Magazine road tests usually weigh the test vehicle in this condition.
Design weight: - GM engineer-speak for gross weight - say two 150 pound people and 100 pounds of cargo, so add 400 to curb weight.
(Note that my latter two definitions conflict with a previous post.)
If you want a really accurate answer, many automotive performance shops have four wheel digital scales, especially Porsche shops because vintage 911s with torsion bar suspension can easily be "corner balanced" by equalizing torsion bar preload side to side.
The 3460 you mentioned sounds more like curb weight than design/gross weight.
C2 Corvette weight, and most cars for that manner, usually see increases for each generation over the multi-year model run. For example, the C2 disk brake system is heavier than the superseded drum system. Also, owner changes tend to increase weight - steel belted radial tires weigh more than equivalent size bias-ply tires.
Back in the sixties I weighed my SWC (L-76, M-20, G-81, J-65, Wonderbar radio) on a truck scale. It had about 3/4 fuel and a small suitcase in the back. It came in at 3050 lbs, but that scale may have had only 50 pounds granularity.
As a general rule, everything else the same, big blocks add about 150 pounds over small blocks, and it's all on the front end.
Shipping weights and option weights are listed in most AMA specs. If not, try a later model year of the same generation.
Duke
