58 - Front Eyebrow Needs To Be Refinished
I need to repaint the the black eyebrows in the front of my 58. I want to ensure I make this look as original as possible. I am not worried about keeping it NCRS as it is just my daily driver but still want it to look good.
What was the original black finish on these eyebrows? What kind of paint would be best and and suggestions on how to get the best finish would be greatly appreciated. I thank you kindly for any information that can be offered.
I don't know what was original....I used Krylon 1613 INDUSTRIAL Semi-Flat to paint my eyebrow depressions. Mainly because it was easy to touch up on a regular basis and looked fine. That area WILL get rock chips, bugs, etc.. so, simple is better. On a non-judged car nobody will have a clue about the paint down there as long as its black and not glossy.
Terry
When I used the term "silver leaf", I really meant "silver leaf". I've seen the silver colored paint pens, and they are OK...especially for use on plastic-chrome edging that has worn thru.
But, silver leaf comes in very thin sheets of silver. You buy it at craft stores (along with gold leaf and copper leaf, etc). Silver is not that expensive, as the sheets are very thin. All you want is a surface that can polish up and can be preserved with clear coat. You smooth and clean the surface to be covered; then you apply an adhesive to the surface. The "trick" is to lay a silver leaf sheet on the surface without destroying it (sometimes a real-hair brush with electrostatic charge is used to capture the sheet and then apply it to the surface). Once the entire surface is covered with silver leaf, the adhesive is allowed to completely dry. You polish the silver (gently) and immediately shoot with polyurethane clear paint.
It ain't perfect...but it's a lot better than silver paint pens, spray can chrome, powdercoat chrome, or any kind of peel-and-stick chrome foil.
Errrr...
I think you may have posted in the wrong forum...
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,331 Likes
