LED Bulbs for dash cluster & clock
Let me know how you do with the SuperBright LEDs. I tried swapping out the No. 57 bulbs in my '58 with the SuperBright BA9S-WWHP5 and I found the fit with the bulb in the lamp socket to be really loose and they only made intermittent contact. Unfortunately I couldn't do the swap out and my original 57 bulbs will have to do until I find a suitable replacement.
If a bulb does have an intermittant contact, sometimes adding a small glob of solder to the center bulb contact will make it fit a lot tighter.
Plasticman
LED bulbs
I have done it previously without removing the cluster, but my medium size hands, fingers, and wrist are pretty flexible. It certainly is not "fun".
Make sure the bulb sockets are fully seated back into the cluster.
I get to change the bulbs tomorrow (to the Superbrightleds.com LEDs), since they arrived today.
Plasticman
Plasticman
Just got them installed, and I am extremely pleased with them. I installed the Superbrightleds.com # BA9s-WWHP5 (warm white) for the instruments (5 total on a later C1). And they dim like they are suppose to!
Note that I did have to add a small glob of solder onto each of the LEDs center terminal, in order to have them firmly mated in the sockets. I view that as "normal" for old sockets that have lost their spring force (my wiring harness was replaced around 1998).
The 2 speedo lamps are difficult to do, without taking the cluster out, but I managed to do them (have the scrapes on my hands to prove it). Used a long screwdriver to help seat them back in the cluster.
Note that I tried one of the green LEDs in the turn signal indicators, and because I have LEDs in my turn/brake/park bulbs, I have an electronic flasher. The Green LED slowed the flash rate considerably, so I did not use them. Evidently my electronic flasher "needs" the added current from the small indicator lamp.
The Green LEDs are brighter, but I have a loud "clacker circuit" that alerts me to having left a turn signal on, so I really did not need brighter turn signal indicators.
For an example of how effective they are, look at Post #10 in the below thread. Mine look exactly as his does (both the "before" and "after"). Yes, mine were "dim", and now I can SEE! Only difference was changing to the LEDs.
https://www.corvetteforum.com/forums...-lighting.html
Plasticman
Plasticman
LED Bulbs
Plasticman
Plasticman
PS. I feel sorry for you at 30 degrees, we are at4 degrees and wind chill -6.
Stay Warm
Dash & clock
Thanks,
Marty
I changed the courtesy light to LED works great much improved. BUT the second time I opened the door the light stays on. I thought it was the switch, I replaced it but still stays on. Any thoughts?
Note that since LEDs require less current, the old bulb may of been seeing the same "stray" current, but not having enough current to light. Now that you changed it to a LED, that lesser current is enough for it to light. If it is not one of the 3 switches (either "on" or faulty), then time to break out the meter, and track down where that "ground" is coming from.
Good luck,
Plasticman
62-C1 (02-24-2016)
Brighter Dash Lights
not LED in my case....used EIKO # 1895 higher illumaniton for illumation lights only dash and clack....not led but considerably brighter and a whiter softer look...Bill Harrison who Does Dash restoratins for me and manyu mant FORUM members sent them to me to install ...wow big difference order them on line EIKO lighting
My hands don't fit behind the dash to well so I used a pair of 10 inch long surgical locking type pliers you find at most swap meets and the job went easy.
