Has anyone come out with a repo headlight switch that does not heat up and cut off the headlights after several minutes of use? Or is there a solution to the repo ones? This happens with both the original T3 bulbs, but much faster with the halogen bulbs.
I'm somewhat electrically challenged, but I think you could have another problem in your headlight wiring. I have not heard of this issue before. Dennis
There was an article on the repo switches at least a year back documenting the internal circuit breakers as being somewhat weak and kicking out, resulting in the headlights going out until the CB cooled off. I've checked firewall connections, cleaned the terminals at the bulbs, checked and cleaned terminals on the dimmer switch, tried a spare dimmer switch. All wiring is new. Headlights work fine with the original switch, just the dash dimmer part is no good due to wire being burned into. Problem only occurs with the repo switch.
It's a fairly common problem with repro switches. Your choices are:
1.find an oem switch
2.keep trying different vendors until you find one that works.
3.Run the headlights directly from the 12v on the horn relay (or run wires from battery) and control them by the headlight switch by inserting a relay between the switch and the 12v supply you choose. Doing this will make your lights brighter and will cut the current going through the headlight switch by a lot. I mean A LOT.
4. Do the mod to make your lights roll over and come on via the headlight switch, which also eliminates the rollover switch. That involves changing out the stock motors and wiring. A kit is available to do that.
The one I got came from LICS, but according to one source on the NCRS site, they all come from CC. Cannot verify this, though. Buns, are any of those you posted American made? I tried yesterday to locate a NOS switch on e-bay with no luck.
65 GGvert, do you have some type of rough wiring diagram showing the configuration of wire and relay from the 12v horn relay to the light switch? Not exactly sure how this would be done and I'm sure others would be interested. TIA Al
Sent you a pm with instructions and included this link with a diagram in post #5.
