C2 Valve adjustment
I have some difficulties about my C2 engine, one side of the block is not running ok as the other one. I think it can be from the valve adjustment. Does anyone can give me some help with valve adjustment of the engine?
Thanks a lot
Hydraulic lifters just need the rocker nuts loosened with the engine running until they make noise, and then tightened until noise goes away with about 1/8 of a turn tighter for wear clearance.
Solid lifters need to be adjusted to a specific lash or clearance specification. Typical stock cams are the 097 (Duntov, or 0.008-0.018) cam, the 30-30 (0.030-0.030) cam, and the LT1 (0.024-0.030) cam (lash clearance in thousands of an inch between the rocker arm tip and the valve stem, Intake-Exhaust).
No cam lash is set in stone. Lash can vary plus or minus 0.000 to 0.015 from the stock GM specifications depending on the cam. GM gentle cam lobe profiles are very forgiving to adjustment. Tighter lash usually benefits higher rpm, loose lash usually benefits lower rpm performance.
Some aftermarket solid lifter cams with faster lobe profile ramp rates need more care with lash, to prevent damage from lifter/lobe contact abuse.
John Hinkley & SWC Duke provide one method to adjust lash, to assure you have the lifters on the base circle of the cam. There is probably a link to this in the FAQ sticky, but Google popped this link.
corvette-30-30-and-other-oem-sb-solid-lifter-cam-valve-adjustment/
Need year of car and engine, engine cu in displacement, and horsepower rating. Also if engine has been modified, and if cam is hydraulic or solid lifter (or roller lifters).
Then we can assist.
Larry
You can buy oil diffusers or else cut up a set of valve covers to adjust the valves. With the engine hot and running back off the adjustment nut (while listening, keep pressure OFF the wrench/socket to let the lifter work freely) until you hear clatter...then tighten things up 3/4 to 1 full turn, pausing at each 1/4 turn to let the lifter stabilize. I don't know anybody that adjust hydraulics only 1/8 turn from zero lash...
Here are oil diffusers.. http://www.jegs.com/i/Mr.+Gasket/720/1015/10002/-1
PLEASE NOTE: Valve adjustment may have nothing to do with one of your engine banks running poorly....could be plug wires, plugs, carb, leaky intake, and, on and on...
The least amount of lash take up on a hydraulic lifter will provide the least amount of lifter pump up at high rpm. The minimal lash allows the piston in the lifter to have more travel to move without floating a valve. The performance limits of a hydraulic lifter can be improved a few hundred rpm from the minimal lash. The tradeoff is wear adjustments are needed more often than 100,000 mile intervals.
With proper lash I could run 6800-7000 rpm with a hydraulic lifter in one of my Pontiacs. In Stock eliminator where the only choices are hydraulic lifters every bit of rpm helped.
And assuming that your oil pressure is still OK....and the engine has not been sittign for a LONG time.
The reason I am mentioning all of this is that there are some cases that I have encountered (3 times in 30 years) where the lifter plunger was stuck in the down position and I could see it when I got the engine into correct position and loosened the nut on the rocker arm.
SO...due to not being there listening to the noise...I have no idea...but it is something WORTH looking into when you have the valve cover off. I assume NOTHING....because if you take up the slack to get the noise to go away....and the lifter is NOT doing what it is designed to do...you will have more problems than just a noise to worry about.
DUB
But from the passenger side above the starter there is a hole where you can see the engine, what is used to close that hole? Silicon?
And just another thing, when the engine is running parked after some time he puts water out, but if you are running with the car it is ok, what it could be?
DUB
If your car is emitting coolant when parked, after being driven, you may have too much coolant in it and it is just pushing out the excess. It should stop after a while and the coolant level in the expansion tank settle down to about 1/2 full.
