C1 clutch return spring
Old Mar 22, 2016 | 02:01 PM
OC-1's Avatar
OC-1
my pics of a 57, 61 and repro spring
Old Mar 23, 2016 | 07:49 AM
58horse's Avatar
58horse
What is the best way to install the "gorilla"?
Old Mar 23, 2016 | 12:50 PM
Plasticman's Avatar
Plasticman
No special tool is required other than a large Crescent Wrench (12" or so).
Assemble the spring at the bottom, then assemble it onto upper bracket (the bracket that bolts to the cross shaft), then assemble the bracket to the cross shaft using the bottom bolt only (leave this bolt loose so that the bracket can pivot in relation to the cross shaft).
Then attach the Crescent wrench to the top of the bracket (across the upper end of the bracket - about a 1" gap at the Crescent wrench) and pivot the bracket into place and insert the top bolt.
Adjust the bracket via the Crescent wrench (in relation to the cross shaft) so that the specified effort is obtained at the pedal, and then tighten the 2 bolts (see the ST-12 for adjustment procedure).
See post #16 in the below old forum thread, to see proper location of Crescent wrench.
https://www.corvetteforum.com/forums...rn-spring.html
Plasticman
Old Mar 29, 2016 | 10:50 AM
cannonsid's Avatar
cannonsid
Originally Posted by jimh_1962
Yeah, replacing the spring is not too difficult to change out. I think I have an extra one. Let me know if you want to replace it with the correct one. What else did they do? It sounds like you found a lot of problems.
Thanks for spring offer.
I ordered a new one already.
Let's see what else did I have to fix:
replace brand new phillips headtail light screws with slot head
They charged him $2500 for a rebuilt four speed with a 60 main case, 61 tail case, and 62 shift cover
$2500 for a rebuilt open rear end
$150 for AutoZone plastic horns
$150 for the wrong bellhousing
$100 for the new but wrong water pump
$100 for a new 62 style front motor mount support
$150 for a cheap 57 style FI air cleaner
$150 for a new passenger oil pan
$125 for new but wrong 61 style draft tube
$75 for new but wrong 59 style four speed shift plate
$350 for very nice but wrong 59 hubcaps
and this is just the beginning but you get the idea.
What is so crazy is that for the same money they could have supplied and installed the correct parts.
I know a few items like the oil pan, air cleaner, diff and the early 58 transmission may have been a cost savings compromise but I could list ten times more examples of lazy and unprofessional work by this big time Southern California restoration shop.
Now that I have whined about the parts, the body work was fine, same for most of the suspension work.
This has made for a fun and easy project to correct easy to change parts.
In a few months I hope to have it on the road again.
I REALLY appreciate the instruction on gorilla spring installation.
I had no idea how to do that and the solution is so easy.
Old Mar 29, 2016 | 10:58 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
Your experience is far too typical I'm afraid....half *** restoration shops who deliver shiny paint and chrome, charge too much, take too long and dick up everything else that matters....
