'64 timing issues
Old Apr 4, 2016 | 11:36 AM
Glen Green 65's Avatar
Glen Green 65
Default '64 timing issues
I have a 1964 327/300. 4-speed. After having the carb remanufactured and installing a HEI distributor, I am having trouble with the timing. The first startup went smoothly, after a bit of cranking to fill the float bowls, it fired right up. During warm up it was running a bit ragged. I tried to set the timing to 8 degrees BTDC as per the FSM, but could not get to 8 degrees, physically moving the distributor. I noticed that the tach drive was pointing at an angle toward the drivers side not to the rear as the original distributor. I decided to try to move the distributor. After finding TDC 0 degrees on compression stroke. I adjusted the distributor. This time the rotor lines up between cylinders 1 and 8 and a bit toward 8 and the tach drive still points towards the drivers side.
When trying to start the engine, it is fighting compression and the second attempt after a distributor adjustment resulted in a very small puff of smoke from the carb. I have tries moving small distributor advance adjustments to no avail.
Not sure where to go next.
Any thought would be appreciated.
Old Apr 4, 2016 | 12:29 PM
Tooth Doctor's Avatar
Tooth Doctor
Double check your spark plug wires, make sure the firing order is correct. Make sure the power wire to the distributor has a full 12 volts, don't use the resistor wire that went to the original distributor to power the HEI.
Old Apr 4, 2016 | 12:44 PM
MelWff's Avatar
MelWff
move each plug wire one terminal on the cap clockwise. This way with the engine at TDC the rotor is just slightly advanced before the number 1 based on your description.
Old Apr 4, 2016 | 04:30 PM
mrtexas's Avatar
mrtexas
The distributor can only be in correct or out 180. Move the wires is a good recommendation!
To '64 timing issues
