Electrical issue re: starting
Having read the Aug 2015 thread titled "New here! 64 with no spark" I followed the all the suggestions and I'm still having an issue.
To begin, the motor wouldn't start. I have no current at the coil. So, I jumped a wire from the + side of battery to the + side of coil. The motor started. Some members said that meant the ignition switch or resister was bad (FYI there are NO POINTS on this dizzy. It has an Accel MSD Points Eliminator kit installed). I disconnected the switch (which is new) and jumped the red hot lead and the black and pink wire (see pic)
. That in theory acts as if the switch is in the "on" position. Still, I'm getting no current to the coil or the ballast on the firewall.
I checked the neutral safety switch connectors (for auto trans only) to insure they were connected, and they were. I went to the starter to check the connections there. All correct.
ALL harnesses are brand new "lectric limited". So what else could I be checking to get current to the coil to run this motor?
Thanks, as always, for any assistance.
Disconnect both wires
You need to verify that you have 9-12V on one wire with the key in the on position.
Second wire will provide 12V with the key in the start position.
When you turn the key from run to start you will loose voltage on the on side.
According to the service manual,the battery connects to the starter and there's 2 leads coming off the solenoid. One goes to the ignition switch and one goes to the coil. With the key in the "on" position, should I get current coming from either of those leads?
When you say you have no power anywhere in the engine compartment that would lead me to the firewall connectors to make sure they were not corroded and connected property.
Do you have a wiring diagram?
The run wire from the ignition switch goes to the ballast resistor PLUS to the lower fuse where it feeds the temp and fuel gauge plus the parking brake teltale bulb so make sure these are wired correctly and work.
Get under the dash and check that fuse with a test light, this may give you a indication weather to work forward or backward.
I did check all the fuse connections and they're all lighting up on both side of the fuses. My amp gauge also moves when the key is in the 'on' position.
1) You say the motor wont start because you have no power at the coil but if you jumped a wire from the + side of battery to the + side of coil the motor starts.
This statement alone tells me you have 12V coming into the Ignition Switch at the Red wire. If not the starter motor would not turn over with the Ignition Switch.
2) Some members said that meant the ignition switch or resister was bad (FYI there are NO POINTS on this dizzy. It has an Accel MSD Points Eliminator kit installed). I disconnected the switch (which is new) and jumped the red hot lead and the black and pink wire (see pic)
That Pink and Black wire runs from the ignition switch through the fire wall and provides 12V at the ballast resistor. I'm assuming when you jumped the Red wire and black and pink wire you had 12V at the ballast resistor??????
The next step would have been to verify you had 9V at the + side of the coil thus simulating the ignition switch being in the on or run position??????
3) I have a slightly different wire configuration due to the "points eliminator" kit. I get 9V from the black and pink wires when cranking however, as I stated above, I have no current to the coil in the 'on' position so how can I check it?
I can't speak to the "points eliminator" kit or how it's wired and what voltage it needs to operate but when cranking the engine with the ignition switch in the start position you should see 12V not 9V. When you turn the key to the start position is sends 12V to the "S" terminal of the starter solenoid which engages the starter and also sends 12V through the "R" terminal straight to the + side of the coil. This is referred to the 12V start circuit.
4) I have NO power anywhere in the engine compartment.
This one has me a little confused what to you mean by NO power anywhere? Is this just on the ignition harness or both the ignition harness and headlamp harness?
It sounds like your problem might be in the wiring connections for this "points eliminator" kit but that aside I would verify the power coming from the ignition switch through the fire wall to the ballast resistor is correct and the 12V start circuit is correct.
Hope this helps, we will figure this out.
You can then check for 12V at the red wire at the ignition switch connector - if you don't have that something is wrong between the bulkhead connector and ignition switch.
If there is 12V at that connector then with the ignition switch in START then it merely remains to see there is 12V at the switch side of the ballast resistor (pink wire from ignition switch) and that 12V arrives at the + side of the ignition coil.
When you ran the jumper wire from battery + to ignition coil + you 'hotwired' the car to bypass ALL of the above electrical magic -- that's all.
Soooo.....somewhere in what I described above the same 12V you forced to the ignition coil with the jumper is NOT arriving at the coil through the designed ignition circuit.
The failure point is somewhere along the path described above...there are no fuses involved in any of the above.
If all of that yields 12V at the ballast resistor you can then jumper across that resistor to see if the car starts/runs. THEN we can trouble shoot the "RUN" circuit...which involves other wiring.
