66 BB Clutch Problems
Here is what I have:
I used other information to verify the lenghts etc..
The car was apart when i got it. I have never seen these parts work together before, but based on documentation they should.
444 Bellhousing
stock BBC flywheel
1.25 throw out bearing (one that came with LUK)
1.5 clutch ball (not the early smaller one, the replacement)
LUK Clutch pressure plate kit 11"
9" clutch rod
Adapter on clutch pedal and spacer in place for BBC
Z-bar looks correct angle (confirmed it's 155 degrees)
Problem:
When the car IS NOT running i can put it in gear etc
When the car is running NO WAY can i push the clutch in far enough to disengage clutch plate
Here is what I have checked:
I took everything back apart and the clutch disk can only go in one way and it's noted "flywheel side"
adjusted the clutch per specs, then even went more as a test, no luck
Re-adjusted the shifter for neutral alignment
I had someone press the clutch in and the clutch fork looked to have moved over 1" easily. I could see that it did appear to be depressing the diaphragm pressure plate.
Any similar experience? What did you do?
How much free play at top of pedal? Take all of the free play out as an experiment and see if it will shift in and out of gear.
But yes - lots of similar problems lately. One inch movement on the outer end of the fork is not going to be enough movement at the TO bearing to disengage many clutches. I'll try to find a couple threads on this and post.
I took all free play out and still no luck. I was at the bottom of the clutch rod. and it's the 19" rod too.
I was working on this about a year ago, and just now am able to get back to it. I got injured, so just now getting so i can bench press a muncie again
We left off with the possibility of the clutch plate being backwards. Now fast forward, same problem but we know what it's not as far as clutch plate. How much free play at top of pedal? Take all of the free play out as an experiment and see if it will shift in and out of gear.
Pulled my hair out figuring this out.
https://www.corvetteforum.com/forums...vel-range.html
Recent threads
https://www.corvetteforum.com/forums...tch-cover.html
https://www.corvetteforum.com/forums...releasing.html
The article pointed out that the pressure plate can have similar characteristics of how a cam works. I had no idea, I think my problem may be a crappy clutch setup. Either way, looks like it's coming out again!
Looks like Mr. D also had a problem related to clutch plate too.
Appreciate the fact finding! much appreicated
Recent threads
appreciate the great info provided!
