Starter Help Needed
Old May 20, 2016 | 04:43 PM
Burnt71's Avatar
Burnt71
Default Starter Help Needed
I'm helping a friend with an engine swap. He put a 1973 350 in a 1964 4 speed Corvette. Used the 64 bell housing. Now we cant find a starter that the bolt holes will line up. Engine and trans already in car. Why wont the 350 starter go in ? Been told to count the teeth on flywheel But we already tried every 350 starter NAPA has listed for a 73 or 64. None fit
Old May 20, 2016 | 05:04 PM
karkrafter's Avatar
karkrafter
I thought there was only two starters...one with straight across bolt pattern and one with diagonal bolt pattern..angled was for big flywheel and straight smaller flywheel..bellhousing shouldn't matter either way...right? [As correctly stated by DZAUTO below]
Old May 20, 2016 | 05:20 PM
Burnt71's Avatar
Burnt71
Originally Posted by karkrafter
I thought there was only two starters...one with straight across bolt pattern and one with diagonal bolt pattern..angled was for small flywheel and straight large flywheel..bellhousing shouldn't matter either way...right?
We thought the same thing. Thats why we didnt try the starter befoe putting engine in the car. NAPA lists different starters fo auto and stick
Old May 20, 2016 | 05:24 PM
karkrafter's Avatar
karkrafter
What doesn't fit? I thought they all bolted up but the offset was messed up.
I took a staggered pattern out of my 1980-ish 350 and put a gear reduction in. At first I used the wrong set of holes and the starter drive missed the flywheel...moved it ove to the second set of holes and worked perfect...
Old May 20, 2016 | 07:15 PM
MikeM's Avatar
MikeM
Did you try the automatic starter? I think it would work if you're using the '64 flywheel and bellhousing or just use the '64 starter.
Old May 20, 2016 | 07:43 PM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
GOOD GRIEF!!!!!!!!!!!!!!!!!!!!!!!!!
OK, if you had all the original parts for the 64, then it had the smaller 153 teeth flywheel and the small, 403 style bell housing-------------WHICH WOULD HAVE USED A STARTER WITH A STRAIGHT ACROSS BOLT PATTERN.
Next, if you used the flywheel which was on the 350, THEN IT WOULD HAVE BEEN THE LARGER 168 TEETH FLYWHEEL. Soooooooooooooo, if that is what was used, how did you get a 64 bell housing to fit over the larger 168 teeth flywheel??????????
Last, for Chevy V8 engines, there are ONLY 2 SIZES OF FLYWHEELS: THE 153 TEETH VERSION AND THE 168 TEETH VERSION. PERIOD!!!
A starter with a straight across bolt pattern ONLY mates with 153 teeth flywheel. A starter with a staggered bolt pattern only mates with a 168 teeth flywheel. PERIOD!
Now, with all of that said, and without seeing the parts you have, I can't give you any better information.
Old May 20, 2016 | 11:15 PM
Burnt71's Avatar
Burnt71
We used the flywheel from the 64
Old May 21, 2016 | 12:33 AM
rongold's Avatar
rongold
From: Putnam Valley, New York. Amateur Radio Operator K2NS
Default Starter
Tom (DZ Auto),
If I remember correctly, the mid 70's 350 blocks only had a diagonal starter bolt pattern---I don't think they had a third threaded hole on the starter pad. If that is so, then the OP will have to install a 168 tooth flywheel and the larger bell housing. There's no other way around it. The diagonal pattern starter will not fit into a 403 bell housing.
RON
Old May 21, 2016 | 09:31 AM
Burnt71's Avatar
Burnt71
Originally Posted by rongold
Tom (DZ Auto),
RON
I hate the thought of pulling everything out but may have no choice. I plan on laying under it again today . I thought they were all interchangeable. There is a third larger hole but no threads in it doesnt line up with anything
Old May 21, 2016 | 08:09 PM
JohnZ's Avatar
JohnZ
There are two of those un-tapped holes in the pan rail surface, one at each end of the block - they're Manufacturing Master Gage holes, which located the block on precision dowels on the pallet that carried/located the block as it passed through the Machining Department. There's one directly below the fuel pump boss, and the other one is on the starter pad, just inboard of the inner starter bolt.
Old May 21, 2016 | 08:31 PM
Burnt71's Avatar
Burnt71
Drilled and tapped a new hole. Problem solved
To Starter Help Needed
