Too much lead additive?
![](/forums/images/ranks/1k-2k.gif)
2021 C2 of the Year Finalist - Unmodified
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I just added a full bottle of Gunk Motor Medic Lead Substitute to the tank of my '66. It's to be mixed with 20 gallons of gas. But I probably had a half tank..
The car ran great at first, but later on, it wanted to stall and had an irregular idle that I could not tune out at the carb. Has anyone had a problem using this stuff?
ll
ll
![](/forums/images/ranks/11k.gif)
Received 7,089 Likes
2015 C2 of Year Finalist
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
Why did you need it in the first place??? Sounds lik you need to fill the tank up and go for a long long drive
![](https://www.corvetteforum.com/forums/images/ranks/veteran_army.png)
Yup -- get that Snake Oil 'venom' out of your gas tank...and get a 'do over'...
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
![](https://www.corvetteforum.com/forums/images/ranks/veteran_air_force.png)
Received 1,972 Likes
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
I don't think I would drain the tank. Just fill up using quality gas, drive it and fill it up again at half a tank or even a quarter tank so you keep thinning it out. Do that a few times and it will pretty much be gone and it gives you a reason to drive the car!
![](/forums/images/ranks/7k-10k.gif)
Larry
Received 3,446 Likes
What Powershift said. Likely the cause of your ragged running. The only lead additive to run is TEL 130, which is actual tetraethyl lead, and it is used for raising the octane of the fuel. No need to add ANY lead substitute or snake oil to today's poor quality fuel. That said, a small amount of ATF or Marvel Mystery oil added to gas will indeed help leather accelerator pump seals from drying out and will also counter the corrosion to zinc and aluminum carburetor bodies caused by the absorption of water with our alcohol-laced fuels. Where I live, you can not buy non-alcohol-contaminated fuel, so MMO is a good idea. It doesn't take much, though.
I didn't drain the tank, but added 5 gallons of premium with octane booster instead. The plug from #1 cylinder looked fine, so I put it back in and figured the other 7 plugs are okay too. But it still runs like a cylinder isn't firing and stalls. Hmmm.
The only other change I made was I installed a new set of offroad N11 mufflers from Corvette Central, which fit fine. Until I get them welded to the original tail pipes I used collar type clamps which are leaking slightly. So I can't image a restriction and a lot of pressure was coming out of both tail pipes when I had it running (like sh*t) last night, before limping it home.
The distributor is tight, so I can't imagine the timing changing suddenly. I wonder if I have a defective plug wire? I'm thinking ignition problem now instead of fuel.
Pulling only one plug won't give you any real useful information. You need to have a game plan for diagnosis. If the car ran fine before the additive, likely you have a fuel issue. If it has a dead miss, you need a vacuum gauge to verify.....and then you need to walk the cap to determine which cylinder isn't contributing. My advice is to use rubber gloves and insulated pliers when you pull each wire from the cap with the engine running. If you have no idea what I am talking about, you should take your car in to a competent mechanic.
The fuel is always fresh, since I take it out every weekend and to shows constantly. I do all of my own work, and have been restoring Corvettes (on #14 now) for 35 years.
It's just odd because I finished installing the new N11 off road mufflers and put in the lead additive (which I've used many times before without a problem) at the same time. Then I drove it to work about 5 miles away and it ran perfect. It sat in my parking lot for 4 hours, then after work I drove it straight to a local cruise. And that's when it immediately ran lousy. No warning. From great to crap.
Being the suspicious type, I can only suspect some spiteful activity by guys who were cutting the company lawn nearby.
But I see no sign of sugar or anything discolored in the fuel tank. The primaries on the carb (vacuum secondaries) are pumping out fine also. I do have a spare identical carb that I can throw on. And I also thought about installing temporary (non factory braided) plug wires when replacing the plugs. I can't get it to run, so checking vacuum is out.
![Skeptical](https://www.corvetteforum.com/forums/images/smilies/skep.gif)
![](/forums/images/ranks/3k-4k.gif)
PS stop adding miracles in a bottle to your fuel. ☺
![](/forums/images/ranks/2k-3k.gif)
![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
Gerry
The additive you put in is not lead. It probably isnt related to the missfire you describe and I doubt it has any benefit in providing valve seat protection.
Do the current engines with aluminum heads have hardened valve seats?
I don't know... just askin'.
Gerry
One step further. Couple of folks I know have taken the heads off their engines and had the valve seats modified to supposedly run without issues on unleaded gas and they had horrible results. I would never recommend having heads reworked for that purpose.
Back to OPs original problem.
I would drain the tank and stop using additives unless it is a stabilizer for long periods of non usage.
Next I would change any fuel filters. After ruling out any fuel related issues I think it is time for a compression test and if it passes start chasing down the apparent ign problem maybe even getting rid of of the points and installing an electronic system.
