Trim tag, VIN tag and engine stamp verification
Received 6,943 Likes
2015 C2 of Year Finalist
the only way to know for sure is to find anther BB engine that was assembled within a day or two of this one and compare. not all stamp pads will look the same.
65specialk (07-12-2016)
Inspection
Thank you all for your comments and opinions. It seems that the only way to make sure of what I'm buying is to hire a professional which I'm willing to do. Does anyone have a recommendation for a NCRS member that is close to Springfield Ohio that could appraise or access the car?
Received 1,857 Likes
provette67 (07-23-2016)
He is a great guy and very knowaglbe and trust worthy
One would wonder why would a seller restamp a bare block that is out of a car with no car attached to it. Seems there is no gain for the seller to stamp a bare block unless the project car comes with it.
Jeffthunbird (11-03-2018)
The last letter was not always stamped with the rest of the letters. It was stamped once the final driveline configuration was determined. Thus the potential for misalignment.
Tom
Tom
#33
I think the real question is as to whether the "L" in the Ebay ad (and the OP's post as well, for that matter) is original. The offset and deeper strike make it appear to be added later and raise strong doubt in my mind - as has been stated by other posts as well.
#34
I understand your point to be correct in some cases on lower hp engines, but in this case as a 427 isn't about the internals of the engine?
#35
That was common practice for many small blocks as well. That is not the reason I questioned the validity of the block in the OP's post. The one in the E-Bay ad looks very good to me.
#36
The best thing would be to have a couple images of pads of the same engine config around the same period and do some comparing.
I'm no expert and won't ever claim to be either so take my opinion with a grain of salt....... I've attended a technical seminar on this subject and left them knowing that if I were ever in this buying situation I would involve someone with much greater knowledge then I.
Tom
#38
#39
The machine used at the engine plant was as big as most local machine shops are. In other words it was done on a diffident machine then used today by local shops who deck blocks. I'm not sure what style cutting tools any one uses. But I do know diffreant tools and diffreant speeds and feeds will make diffreant end finishes.
#40
