[C2] Head Light Bezel
Old Oct 29, 2016 | 11:27 PM
Tim Beilby's Avatar
Tim Beilby
Default Head Light Bezel
1966 C-2
I am looking for the correct flat head Phillips screws for the headlight bezel's
I have been told they need to be #8 with a #6 head.
Old Oct 29, 2016 | 11:47 PM
65hihp's Avatar
65hihp
Do you mean these?
Paragon has them.
https://www.paragoncorvette.com/p-35...screw-kit.aspx
Old Oct 30, 2016 | 09:26 AM
Tim Beilby's Avatar
Tim Beilby
The ones to the left look similar although they are suppose to be cadmium or zinc plated per the NCRS 1966 Technical Manual page 73 top.
Thank you for your suggestion.
Old Oct 30, 2016 | 09:46 AM
65hihp's Avatar
65hihp
If you want the screws that hold the cover to the front of the headlight bucket, these are the correct screws. Two are silver color plated (the uppers) and two are black phosphate (the lowers) on each cover. And the same answer applies on the TDB as here.
Old Oct 30, 2016 | 10:29 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
You may just want to rotate the buckets with the thumbwheel that first time to make SURE the heads on the screws are correct and they are tightened enough. Screw that up and you'll gouge a nice semi-circle in the nose of your car. Do NOT ask me how I know!
To Head Light Bezel
