interior Door lock Handle trim
Old Nov 5, 2016 | 04:21 PM
egerson's Avatar
egerson
Default interior Door lock Handle trim
1958 C1
I have a photo of the plastic behind the door lock .
This is part # 481336 in Corvette Central catalogue,page 108.
As you can see, it is cracked and broken.
My question is --- how hard is it to get the door lock off in order to replace this round plastic piece? Is there a special tool needed?
thanks
ED G
Old Nov 5, 2016 | 04:50 PM
treh1's Avatar
treh1
There is a clip that fits into a groove on the backside of the door lock that keeps it in place. It's fairly simple to remove with a thin-bladed screwdriver. Depress the door panel to expose the clip. Here's a photo of the clip and one that's 1/2 onto the groove.
Old Nov 5, 2016 | 11:49 PM
R66's Avatar
R66
The shop towel worked best for me.
Take a shop towel or an old nylon stocking (not the wife's new ones) and feed it between the plastic trim and the ****. Pull on one side and then the other to work the clip out of the groove. If it doesn't work in one direction, try from the back side as someone may have put the clip on backward.
I spent a lot of time with a brake adjustment tool before I learned the rag trick right here on the forum.
But, Yes, they do make a tool to do it also. Don't have a P/N, but NAPA and other good parts shacks will have it.
Old Nov 6, 2016 | 06:27 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
Something looks hinky with your nylon washer under that ****; it should no extend past the circumference of the ****...
The vendor tool works on side window and vent window cranks....its not worth a hoot on C1 or C2 door locks. I've never got the rag trick to work either. Here is my method. I fumble a bit in the first video because of trying to position the camera while working - it is actually easy to do.. The blue tape 'pointer' is to show me where the ****'s lever is pointed...to reinstall it properly.
File Type: wmv
File Type: wmv
Old Nov 6, 2016 | 05:15 PM
egerson's Avatar
egerson
Default thanks for videos
the videos are super and much appreciated.
did you do this just for me, or did you have it already on file?
ONE question. looks like you pushed the clip all the way down before reinstalling it. Is that right? will it push ON with it already pushed IN?
thanks
ED G
Old Nov 6, 2016 | 05:32 PM
Frankie the Fink
Army
thanks
ED G
Videos were already done and yes the "U" clip should be completely seated before you pound it on the shaft. The clip will expand when you hit it then spring back to hold the ****.
To interior Door lock Handle trim
