[C2] Comp Cam Specs
Old Nov 8, 2016 | 05:41 AM
waveguerilla's Avatar
waveguerilla
Default Comp Cam Specs
Hi,
I don't know if this cam is the cam I have now but it may and I would like to know what the specs of it tell (1966 427):
I think my internals have been changed to hydraulic roller lifters. Does this cam is good for that ?
Thanks.
Old Nov 8, 2016 | 09:33 AM
65tripleblack's Avatar
65tripleblack
It's a solid lifter cam.
I don't see the need to nitride treat a roller cam.
Old Nov 8, 2016 | 09:49 AM
waveguerilla
Ok, but how to know which cam is installed and if it is a good cam for the engine ?
The engine rebuild was in 2004, I have the invoice, I have this comp cam specs but I don't know when it was installed and I have another invoice of cam change in 2009 but without any detail by JF automotive machine shop.
Do you think it is important to know wich parts are really in the engine ?
Old Nov 8, 2016 | 10:57 AM
65tripleblack
Depends on your curiosity. The only reason would be to know if parts are compatible with each other. If the engine has been running since the 2009 cam change, then I wouldn't worry about it unless something's wrong.
If you want to know if it has hydraulics, then run the engine and pump up all the lifters, then remove the left valve cover and wiggle any rockers that are in closed position. If they're tight or show resistance, then you have a hydraulic cam and lifters. To be dead sure, put #1 cylinder @ TDC of the compression stroke (rotor points to #1, not #6), and wiggle both #1 rockers; they should have resistance. If you have solids with .020 lash, then you should be able to hear them at idle. If they're adjusted properly (at .020/.020) then the sound will be like a chorus gently singing a single note, not a clatter.
Overlap is 10.5 degrees, which is fairly mild for a 427. What's your engine's idle vacuum? I'd guess it's in the neighborhood of 11-13 in-hg @ 750 RPM.
Old Nov 8, 2016 | 12:08 PM
MelWff's Avatar
MelWff
The spec sheet has a serial number. Call Competition Cams and ask when this cam was manufactured which will tell you if it is the 2004 or 2009 spec sheet.
Old Nov 8, 2016 | 12:33 PM
waveguerilla
I will make this test.
I have the detail of what has been changed in 2004 and there was hyd roller lifters and roller rockers, I doubt someone reopened the block to change that parts but I'm not sure :
https://www.corvetteforum.com/forums...post1593422093
Good idea !
Old Nov 8, 2016 | 12:34 PM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
The picture of the cam spec sheet has an '09 serial number.
I'd go with that.
Old Nov 8, 2016 | 12:46 PM
waveguerilla
I'd go with that.
You are a genius
So the cam is a cam for solid lifter but works with hydraulic roller lifters, I imagine it is not optimal ?
Old Nov 8, 2016 | 12:50 PM
Easy Rhino's Avatar
Easy Rhino
You are a genius
The speculation was that it was built for solid lifters because it was nitrited. However, who knows if roller cams care about being nitrited? I for one don't. I would think the bigger difference would be the cam ramps, but I'm no genius.
However, Comp Cams has a handy dandy cam serial number checker just for you: http://www.compcams.com/Company/CC/cam-specs/
Check it out.
BTW, a quick look at the Comp Cam catalog seems to indicate that the "R" in your serial number means "roller". See: http://www.compcams.com/Technical/Ca...terCatalog.pdf
Correction - looking at the Comp Cam Catalog, I don't think 9 = 2009.
But I do think your cam may be on page 14 of the catalog - #5539? If so, it's a hydraulic flat tappet?
Old Nov 8, 2016 | 02:44 PM
65tripleblack
Lobe #5681 is a solid flat tappet.
Since the cam described in the cam card a flat tappet cam, then that would explain the nitride treatment. Nitriding hardens the surface, and provides more durability against sliding friction, which is needed with flat tappets. As I said earlier: there's no good reason to nitride treat a roller cam..........solid or hydraulic.
But the OP doesn't know if this is the cam in his engine, or not.
Old Nov 9, 2016 | 09:45 AM
waveguerilla
Ok, thank you, I will enjoy the car as it is, keeping in mind I have perhaps not the best cam for this engine, but the idle is rough, I love it.
I don't know yet if the engine is good at high revs but I hope.
Old Nov 9, 2016 | 09:47 AM
waveguerilla
Idle (without choke)
Old Nov 9, 2016 | 02:02 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
That's a strange cam for a big block. Relatively large duration...and next to nothing on lift.
Definitely not the best cam of performance with OEM heads. It could use a split pattern cam...and a good bit more lift.
But if you're happy with it....I'd leave it alone. The nitriding will help longevity for sure along with the mild lift numbers.
JIM
Old Nov 10, 2016 | 08:34 AM
cv67's Avatar
cv67
St. Jude Donor '05
w/jim
says on card solid flat tappet lash .020
Do not use roller or hyd lifter
Nothing wrong with nitride treat wont hurt anything
Old Nov 10, 2016 | 08:39 AM
Easy Rhino's Avatar
Easy Rhino
Beautiful car, OP.
That idle sounds poor, but you labelled it "cold idle". If it improves upon warmup, then I would not start with working on the cam, but on the carb (and check the ignition).
Of course, these cars idle nothing like modern cars, but yours is pretty rough.
Old Nov 10, 2016 | 09:14 AM
65tripleblack
Beautiful car, OP.
What do you expect at 500 RPM. I'm surprised that it even idles at all at so low a setting.
It should be idling at more like 700-800 with the stated durations.
Old Nov 10, 2016 | 09:16 AM
Easy Rhino's Avatar
Easy Rhino
Hence "check the carb, not the cam".
In the OPs other thread, he notes where carb choke parts are missing, so there's that.
To Comp Cam Specs
Old Nov 10, 2016 | 09:17 AM
waveguerilla
Ok, I will see when it is warm and maybe I will raise that idle, I imagine it is a sort of screw ?
Old Nov 10, 2016 | 09:20 AM
Easy Rhino's Avatar
Easy Rhino
I think that you should fly me over to France to make sure that your cold and warm tuneup settings are correct for that fine car.
Not wanting to sound harsh, but it might be wise to get someone who knows these carbs to get you set up right. Either that, or break out the books (and this site) to make sure that you are adjusting it right. You have to start with the choke settings first (cold and hot), then set the cold idle stop.
Old Nov 10, 2016 | 09:28 AM
waveguerilla
Lol, what, is there a hot settings for the choke ? What for ?
PS:We have some rare mechanics who know american car and corvette but the best source is this forum
