Remove paint
Old Nov 23, 2016 | 03:20 PM
Hazeldog1964's Avatar
Hazeldog1964
7th Gear
Default Remove paint
Has anyone used glass media to remove paint form your corvette
I've heard positive remarks about plastics media and negative on baking Soda and paint remover but nothing on glass media
Old Nov 23, 2016 | 05:08 PM
Mike Terry's Avatar
Mike Terry
I had my 54 motorama car sand blasted when it was just a 1954 project car. But you have to know what you are doing or you can cut a car in half real fast with sand and the guy who did mine is the best.
Old Nov 23, 2016 | 05:44 PM
bluzrocker's Avatar
bluzrocker
Default blasting body
I did lots of research...talked with many people....decided against soda as residue comes out after the process according to reply's...like inside when you shut the doors /or a ride was told it was present for some time.
My 67 was done with # 6 acrylic beads...and done by a company in Sacramento....and only had one person that does the process....THE OWNER who had the experience and know how not to put a bunch of waves and irregular surfaces for the painter/body guy to smothe out.
one other advantage was not having chemicals to strip and the residue left behind..
advantage was painter had the opportunity to see any cracks and areas of concern and would guarantee his work .....also my painter deducted the price of the bead blast from his quote as a 3rd party did the strip....cost was $1,200 to me was worth that process
Old Nov 24, 2016 | 10:53 AM
Mr D.'s Avatar
Mr D.
I have always used Capt Lees stripper, never had a problem.
Old Nov 24, 2016 | 10:56 AM
Hazeldog1964
7th Gear
Thank you but the shop that is painting my car will not warranty his work if I use paint remover
Old Nov 24, 2016 | 01:18 PM
Mike Geary's Avatar
Mike Geary
Is plastic media blasting available in your area and have you been quoted a price? PMB is pretty much the ultimate method for our application IMHO.
No way would I let a stranger hit one of my cars with either sand or glass beads....
Just as an FYI, I use aircraft stripper but only down to the primer.
Then it's lacquer thinner and scrubber pads.
Old Nov 24, 2016 | 01:37 PM
Gary's '66's Avatar
Gary's '66
Personally, I would find another painter. I say this because it sounds as though he doesn't know much about Corvette repainting procedures since using strippers are pretty much the norm and, have been for many, many years.
I recently had my car repainted by one of the best in the business here locally and he, of course, used a stripper! My .02
Gary
Old Nov 24, 2016 | 01:49 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
Gary, I wonder what he used ? Captain Lee's is no longer made and I have another car to strip.
Old Nov 24, 2016 | 01:55 PM
Gary's '66's Avatar
Gary's '66
I'm not sure but, I could find out. In the mean time, this sounds like a job for............. datadadaaaa........ DUB!
Gary
Old Nov 24, 2016 | 03:34 PM
chvlle383's Avatar
chvlle383
I'm just going to sand mine..Very carefully.......i don't trust chemicals, and can't stand the smell......
Old Nov 24, 2016 | 05:11 PM
ChattanoogaJSB's Avatar
ChattanoogaJSB
i used kleen strip "aircraft" stripper for fiberglass. Neutralized with lacquer thinner.
DUB among others referered me to this. I will talk to you about my experience if you like. Horrible job, no way to say it otherwise, but the stripper does work.
Old Nov 24, 2016 | 06:39 PM
Dave Tracy's Avatar
Dave Tracy
There is a dry ice blasting process that leave no residue. Would leave a large carbon footprint
Old Nov 25, 2016 | 10:25 AM
Pop Chevy's Avatar
Pop Chevy
Thanks for the heads up. Looks like I will be using aircraft stripper from now on. I used it yrs ago then found Cap'n lees. Best stripper I ever used. Even used it on my carbon fiber formula car w/ multiple layers (and colors) of paint, probably took 15 lbs of paint off ! No, I would not use an abrasive blast.
Old Nov 25, 2016 | 10:58 AM
Roger Walling's Avatar
Roger Walling
I have used crushed glass media on a sample trial.
It was a hot day and the sweat on my arms collected the broken particles and when I was done, my arms were covered with blood.
I do not recommend using it, unless you are a sadist.
Old Nov 25, 2016 | 04:29 PM
ChattanoogaJSB
Instead you'd be a masochist, Roger! You'd be married to a sadist if your wife enjoyed watching the job...
Old Nov 25, 2016 | 06:17 PM
DUB's Avatar
DUB
For what it is worth:
As mentioned...I do use Klean Strip's Aircraft remover. In 30+ years...NOT ONE problem at all. NO JOKE! If the smell bothers you. ****NEWSFLASH**** they make respirators....buy a respirator. The smell does not bother me...but I am not working in a fog of vapors. I work in a WELL VENTILATED AREA.
For those who want to sand off the paint.....have at it. Let us know how it goes when you get to the tight 'nooks and crannies'. Because those areas are where you will more than likely have a problem.
I also use sand when I blast and prep areas. A real time saver.
I would like to try the dry ice method on a panel. Some of the new paint really sticks and event the Aircraft stripper does not even touch the clearcoat.
And I always try to remove any paint that can easily come off using a razor blade.
'Hazeldog1964'. I know shops have their own way of doing things....so it does not surprise me that they do not want to stand behind their work if it is chemically stripped. I would have no problem with it. Soda blasting on the 'other hand'...I would not waranty.
DUB
Old Nov 25, 2016 | 08:55 PM
Gary's '66's Avatar
Gary's '66
To the OP. It will, of course cost more but, here's an easy solution.
Let the paint shop strip it!
That way the WHOLE job is on them. Then, if any future issues arise they can't use you as a scapegoat which, could actually SAVE you $, as well as a lot of headaches in the long run.
Gary
To Remove paint
Old Nov 25, 2016 | 11:40 PM
randy ransome's Avatar
randy ransome
Winner 2020 C4 of the Year - Unmodified
2018 Corvette of Year
2017 C2 of Year Finalist
2015 C4 of Year
I'm with you on this one DUD I've stripped several corvettes over the years and I've always used Clean Strip stripper. Nothing works as well in my opinion especially in the tight spots.
Just remember to clean everything off each time you finish for the day. I usually rinse with tons of water then wipe it dry.
Old Nov 26, 2016 | 06:40 PM
DUB's Avatar
DUB
Originally Posted by randy ransome
I'm with you on this one DUB I've stripped several corvettes over the years and I've always used Clean Strip stripper. Nothing works as well in my opinion especially in the tight spots.
Except... I prefer to use automotive grade lacquer thinner to rinse with.
But that stripper is the best I know of for getting stuff off without taking all day due to some are seemingly weak chemical strippers.
DUB
Old Nov 27, 2016 | 12:09 AM
randy ransome
2015 C4 of Year
DUB
Actually lacquer thinner is what I use also, but just to be safe I'll usually blast it with some water too.
