12 volt source
Old Dec 31, 2016 | 01:27 PM
skids's Avatar
skids
Default 12 volt source
I need a source for 12V with key on AND while cranking. This is on my 64 w/o AC.
Old Dec 31, 2016 | 01:37 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
For what purpose....current draw is a factor; A/C compressor is a different beast than an electric choke..?
Old Dec 31, 2016 | 01:42 PM
vetsvette2002's Avatar
vetsvette2002
Veteran: Marine Corps
St. Jude Donor '13-'14-'15-'16
Check your fuse panel.
IIRC the power windows were HOT all the time. There may be other points on the box also readily available.
Old Dec 31, 2016 | 01:47 PM
skids's Avatar
skids
Wiring up a Holley HP mpfi.
Old Dec 31, 2016 | 01:59 PM
00fxd's Avatar
00fxd
Of course you're just energizing a relay then ...
Old Dec 31, 2016 | 08:37 PM
skids's Avatar
skids
Haven't tested yet, but is the pink wire on switch hot, when switch is on and cranking??
Old Dec 31, 2016 | 08:39 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Inline fuse to the lug on the horn relay. Problem solved
Old Dec 31, 2016 | 08:51 PM
buns's Avatar
buns
Mine is, and I believe they were meant to be that way. Some claim they lose power to the pink wire when cranking, but I'm thinking they have a faulty switch.
Another choice for power would be the "brake alarm/gas gauge" fuse, top one in the panel. You just need a 'fuse tap'.
To 12 volt source
