headers
Old Jan 6, 2017 | 03:53 PM
gringo76's Avatar
gringo76
8th Gear
Default headers
what are you guys doing about the alternator when installing headers. my 327/365 exhaust manifold is part of the alternator bracket.
Old Jan 6, 2017 | 04:24 PM
Avispa's Avatar
Avispa
Depending on what side your alternator is on, this might work. There are other brackets as well.
http://www.partsgeek.com/8jk8r28-che...ad=11620898017
Old Jan 6, 2017 | 04:56 PM
gbvette62's Avatar
gbvette62
The Hooker Headers that are on my 62, came with that bracket, and it's served me well for years. Those brackets have been known to crack around the bolt holes, but from my experience it's not a common occurrence. I have been using that bracket with an alternator, since my 62 has been converted from a generator.
Old Jan 6, 2017 | 05:26 PM
DUB's Avatar
DUB
I will add that you just make sure you REALLY make sure the alternator is secure. Some of these brackets they offer will work but can fail.
I see many engines with this type of bracket and when the engine is running I can watch the alternator move. I mention what I see ( and actually show them also) to the customer and they say: "Its been working for for years." I just shake my head because I KNOW in time..the car will be back in the shop to get this area re-engineered and a better bracket fabricated....becasue of the bad wear on the belt also..
DUB
Old Jan 6, 2017 | 06:51 PM
bcwaller's Avatar
bcwaller
C2 of Year Finalist (performance mods) 2019
If you are having new headers put on, and you buy them bare for coating later, you can have the bracket welded onto the header. Most shops can even make it for you. Then you can coat the header with the bracket.
If not, then buy the header mounting bracket (and secondary bracket that the alternator bolts to if needed) and use them. Make sure you get the one for the side of the engine the alternator is on.
Old Jan 6, 2017 | 08:51 PM
toddalin's Avatar
toddalin
Header Power Bracket has you covered. These were developed on the midyear and are the coolest and strongest of the header alternator mounts.
http://www.headerbracket.com/index.html
To headers
