62 corvette
Old Jan 15, 2017 | 03:27 PM
grhardee's Avatar
grhardee
6th Gear
Default 62 corvette
What is the procedure for drag link ball adjustment preload? Installing new kit with ***** and springs and seals. Thanks
Old Jan 16, 2017 | 12:43 PM
K2's Avatar
K2
The adjustment procedure is;
1. Remove cotter pins from ends of sockets and tighten plugs snugly to remove end play.
2. Back off screw plugs 1/4 to 1/2 turn plus amount necessary to insert cotter pin.
Also make sure the length is adjusted to center steering wheel when wheels are in the straight ahead position.
By the way, Welcome to the forum!!!
