[C1] Water Pump Install
Old Feb 14, 2017 | 08:03 PM
  #81
wmf62's Avatar
wmf62
St. Jude Donor '07
Originally Posted by jim lockwood
I'm going to cast the dissenting vote here.
The WP pulley appears to be the deep groove variety while the crank pulley looks to be the standard groove variety. That is significant.
The groove spacing on the two types are different and it's impossible to make both belts align correctly. If my eyes are not playing tricks on me, the two belts appear to be closer together as they wrap around the crank pulley than they are as they wrap around the WP pulley.
Norm, are these the pulleys advertised as having both come off the same engine?
Jim
It is definitely better than it was....
Bill
Old Feb 14, 2017 | 11:23 PM
  #82
59BlueSilver's Avatar
59BlueSilver
2023 Restomod of the Year Finalist
I installed the belts, and yes there is a variance. The top measures .20", bottom is .16", .040 difference, less than 1/16". Is that going to make it unusable?
Old Feb 14, 2017 | 11:28 PM
  #83
59BlueSilver
BTW, using a straight nipple puts my heater hose in a kink. Does anyone know where I can get this connector with a 45 deg. nipple? I've seen pics of it but can't find it again.
Old Feb 14, 2017 | 11:47 PM
  #84
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Originally Posted by 59BlueSilver
That's what the seller said. Double groove water pump (#3790356CH) and 2 piece 3 groove crank pulley (#3744043BA-3751232GM)? I didn't install the 3751232GM.
Norm,
The "356" WP pulley is the one I recommended earlier. The "232" pulley is what you'd want if you were adding PS; you might want to hang on to it for a while.
I don't know what the "043" pulley is. It's not a Corvette pulley or perhaps it supersedes the pulley which matches the "356" WP pulley. Either way, it's not in my 1971 P&A book.
Regardless, my eye still says the pulleys don't all match up properly.
Jim
Old Feb 15, 2017 | 04:06 AM
  #85
wmf62's Avatar
wmf62
St. Jude Donor '07
there is also a short nipple
Bill
Old Feb 15, 2017 | 07:31 AM
  #86
jim lockwood
Norm,
This is what you want:
Corvette Central part #451324
Old Feb 15, 2017 | 08:04 AM
  #87
wmf62's Avatar
wmf62
St. Jude Donor '07
Norm,
it's amazing the oddball stuff that is available
Bill
Old Feb 15, 2017 | 08:09 AM
  #88
59BlueSilver
Norm,
Yeah, that is what I need alright. Thanks!
Old Feb 15, 2017 | 08:22 AM
  #89
jim lockwood
Bill
According to the CC listing, that bent nipple was used from '56 thru '58.
I *knew* I had seen one.... just had to look for it.
Old Feb 15, 2017 | 08:32 AM
  #90
59BlueSilver
Norm,
Jim
I don't understand. The link you sent me, crank pulley 250/300 hp, is an "043" pulley according to CC and that number is stamped on the pulley I have. The WP pulley is also stamped 356.
Old Feb 15, 2017 | 12:14 PM
  #91
jim lockwood
Neither do I. I recommended the correct parts and the CC part numbers are correct. Yet the two belts clearly don't run parallel to each other.
I suppose one of those pulleys was made incorrectly but I don't know which one without holding them in my hands and comparing them to known good pulleys.
So the question becomes what to do? The most pragmatic answer is "nothing". Run them like they are and see if you notice any problems..... belts being thrown off, rapid belt wear, etc....
Jim
Old Feb 15, 2017 | 01:10 PM
  #92
59BlueSilver
Jim
I can't imagine .04 making any difference since there is more play than that on things running off those pulleys, but who knows! Thanks for all your help on this, I certainly appreciate it!
Old Feb 19, 2017 | 05:44 AM
  #93
59BlueSilver
Got everything installed, had to not only use the .25" spacer on my crank pulley, but had to add .10" washers also. The thing I feared most about doing this was the WP leaking around the motor mount. It looks great, nice & tight. Had a small leak at the heater hose fitting but think that's resolved. Alternator seems fine, reved to 4K and the belt stayed on.
There is a very short shrieking noise when the engine starts I can't figure out. Not there when I disconnect the alt belt.
Today I'm installing the compressor belt and see how that goes. No power to the compressor yet.
Old Feb 19, 2017 | 09:15 AM
  #94
HilltopClassicCars's Avatar
HilltopClassicCars
Alternator seems fine, reved to 4K and the belt stayed on. There is a very short shrieking noise when the engine starts I can't figure out. Not there when I disconnect the alt belt.
Alternator belt not quite tight enough?
Old Feb 19, 2017 | 08:07 PM
  #95
59BlueSilver
Yep, you're right, thought it was tight enough, but no. Thanks!
Old Feb 19, 2017 | 08:58 PM
  #96
HilltopClassicCars
Old Mar 12, 2017 | 04:31 PM
  #97
59BlueSilver
Just to wrap up this thread, everything is running great. Belts are not showing abnormal wear and they're staying on. Got about 100 miles on it, no leaks. Thanks to everyone for helping on this, I'm very satisfied with the results.
Also, thanks to Hilltop Classic for the tip about that fuel pump push rod bolt, that's where most of my leak was coming from. Glad I wasn't able to remove the balancer!
Old Mar 13, 2017 | 09:29 AM
  #98
HilltopClassicCars
You're not the first one to have that fuel pump push rod hole leak and won't be the last, glad that helped out and your belts are tracking well.
