mini brake booster
Old Feb 3, 2017 | 07:21 PM
67ermineconvert's Avatar
67ermineconvert
Default mini brake booster
Has anyone tried to find a mini booster (7inch) for their bb 67 vette? i ordered some relieved shorty valve covers for my bbc conversion. If i end up using a full roller aluminum head set. am i destined to purchase a hydro boost set up?
Old Feb 3, 2017 | 09:22 PM
3JsVette's Avatar
3JsVette
I have a 7" in my '55 Nomad with a ZZ3. While they work they do run out of vacuum if you have to step on the pedal repeatedly.
Old Feb 4, 2017 | 09:41 PM
67L88Vette's Avatar
67L88Vette
I used these "chinese" VCs that were taller than OEM and had no drippers on my '67 ...
http://www.ebay.com/itm/BBC-Chevy-39...vzYzdg&vxp=mtr
I stripped off the cheap orange paint and resprayed them with KBS Chevy Orange engine paint. They fit fine over my Scorpion roller rockers, although I did have to buy shorter rocker lock nuts. The bolts holes were a little off, but they bolted down okay, and if you use a good Felpro cork gasket, they don't seem to leak ... Here's what they look like on my car ...
Old Feb 5, 2017 | 07:02 PM
DUB's Avatar
DUB
Not that my opinion means anything...but I would install the hydroboost system. I have installed them and they DO work really well.
I also do some improvements to the kit I get from Hydratech. Mainly in the fittings/clamps so they look good on the resto-mods I am installing them in. I do not want regular hose clamps to be seen...I want AN fittings and hose routings to flow...so some more fittings were required from the Corvettes I installed them in.
I have replaced MANY of the small diameter vacuum boosters that were bad...with the correct GM ones also when clearances are not involved.
DUB
Old Feb 5, 2017 | 07:51 PM
NightshiftHD's Avatar
NightshiftHD
Now THAT IS a motor! I want it! Bill
Old Feb 5, 2017 | 08:11 PM
67L88Vette's Avatar
67L88Vette
Thanks, Bill ... Nothing like a L-88 clone to get the blood flowing, LOL ...
John A, 67L88Vette
Old Feb 6, 2017 | 07:28 PM
DUB's Avatar
DUB
Sorry for the hijack...
VERY VERY NICELY DONE!!!!!!!!!!!!!!
I can see a lot of time spent on this engine and engine compartment. And that is putting it mildly.
QUESTION: The fuel filter you have in-line a the front of the right head...who made it and what is its micron value if you remember.
I do fuel systems much like this and the billet fuel filter I use is a 40 micron.. SO I am just curious.
PM me if you care to do so.
DUB
Old Feb 6, 2017 | 10:21 PM
67L88Vette's Avatar
67L88Vette
DUB, PM sent ...
John A
To mini brake booster
