side window alignment
Old Feb 24, 2017 | 04:35 PM
Mikado463's Avatar
Mikado463
Default side window alignment
My drivers side window including vent window / frame is slightly angled out from the a pillar, maybe a quarter inch or so at the top. I've been told that this can be adjusted by removing door panel and making adj from there ?
does anyone have knowledge of this, procedures involved perhaps a you-tube video, etc
I'll try and get a pic posted to better clarify what I mean.
Old Feb 25, 2017 | 12:27 PM
Mikado463's Avatar
Mikado463
Here's a pic if it helps to show the gap I'm talking about .......
Old Feb 25, 2017 | 01:00 PM
Mike Geary's Avatar
Mike Geary
https://www.corvetteforum.com/forums...djustment.html
Old Feb 25, 2017 | 01:01 PM
Mike67nv's Avatar
Mike67nv
2018 C2 of Year Finalist
2015 C2 of the Year Finalist
The Chassis Service Manual for your year will have the information you need. It’s in Section 1B, Corvette Body – Doors – Adjustments - Door Window and Vent.
Old Feb 25, 2017 | 01:57 PM
Mikado463's Avatar
Mikado463
Mike & Mike ....... Thank you !!
Old Feb 26, 2017 | 10:35 AM
RK-TECT's Avatar
RK-TECT
Does the same offset/gap exist when the top is down? My vent window frames push out a little when the top is up, but when the top is down they are nearly perfectly aligned. I removed the door panels when I re-chromed my vent window frames and adjusted them accordingly, but the convertible top bumps them out a bit at the top when it's up. I'm not sure if that's typical on all roadsters, but that's how it is on my car.
Good luck, Roger
Old Feb 26, 2017 | 01:08 PM
Mikado463's Avatar
Mikado463
No Roger, the alignment is off regardless.
Dave
To side window alignment
