block numbers
Old Mar 9, 2017 | 03:25 PM
reno stallion's Avatar
reno stallion
C2 of Year Finalist (appearance mods) 2019
Default block numbers
My friend thinks he has a 63 corvette block here's the stamped numbers on the deck v0809hc casting numbers 3892657. Anyone know?
Old Mar 9, 2017 | 03:37 PM
A-Snake's Avatar
A-Snake
Check the date code on the block. It is a '67 327 275hp 4V used with a Powerglide in a passenger car.
Old Mar 9, 2017 | 03:43 PM
MelWff's Avatar
MelWff
1965 327/275 HP powerglide full size car
V0809HC Flint August 9th
Old Mar 9, 2017 | 03:45 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
According to my source material, with the HC code, it's a '69 Camaro 350/250/2bbl. The casting # shows the block could be used in 302 for Z-28, car or truck and last, the Camaro. Dennis
Old Mar 9, 2017 | 03:48 PM
reno stallion
Default not
so not corvette?
Old Mar 9, 2017 | 04:05 PM
Bluestripe67
In my source material I didn't see the HC code used on any Vette engines. Dennis
Old Mar 9, 2017 | 04:29 PM
MOXIE62's Avatar
MOXIE62
so not corvette?
Take your pick. You got three different cars to choose from. For sure though, it's not a 63 corvette block
Old Mar 9, 2017 | 04:42 PM
A-Snake's Avatar
A-Snake
so not corvette?
The 3892657 block number was used as folows:
1967 3892657 302 290hp
1967 3892657 327 210hp or 350hp 2
1967 3892657 350 295hp
The 'HC' suffix was used in the following:
65 327 250hp 4v passenger car powerglide
66 327 275hp 4v passenger car powerglide
67 327 275hp 4v passenger car powerglide
68 327 275hp 4v passenger car powerglide
69 350 250hp 2v Camero, Chevelle, El Camino, Nova
The 'V' prefix for Flint began in 1967.
Check codes in The Lime Book 1955-1991 4th Edition and http://www.nastyz28.com/sbchevy/sblock.html for block usage.
To block numbers
