C2 clocks
Old Mar 22, 2017 | 10:49 AM
Renwaltoys's Avatar
Renwaltoys
Default C2 clocks
what is the life expectancy of a C2 clock when it is rebuilt before it has to be done again?
Old Mar 22, 2017 | 10:57 AM
66BlkBB's Avatar
66BlkBB
St. Jude Donor '13-'14-'15-'16-'17
I'm not sure there is an easy answer to this question. I would assume that it would be the same as when the clock was first produced. They weren't all that dependable. Maybe someone who has owned their car since new can relate when there clock stopped working. Other than that I have to believe it is just guess work.
Old Mar 22, 2017 | 11:18 AM
Mike Geary's Avatar
Mike Geary
One of mine re-done by Clockworks with an original movement is still going strong after 8 years. And I don't routinely disconnect the battery.
The latest clock I had done was converted over to the ISI quartz movement and I'm happy with the sweep second hand action.
Won't pass judging (no reset sound, stops immediately with power removed), but should have long life expectancy.
One note, with the quartz unit on the bench and higher wattage 1416 bulbs activated, it got hot enough to stop the movement. Ran fine after cool-down.
Backed down the bulbs to 1414's which I am using in all the panel lamp locations.
Old Mar 22, 2017 | 11:24 AM
Renwaltoys's Avatar
Renwaltoys
Thanks Mike!
Old Mar 22, 2017 | 11:29 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
The other week I put 12 volts to a clock that has been sitting since 1975 and the clock has never been out of the dash and it still worked.
Old Mar 22, 2017 | 11:30 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
My 63 clock redone by Clock Works came with a tag stating that removing power from it when not in use will extend its life. I hooked up a 12V relay to it operated by a key fob and only run it for shows/judging. Then there is this little article I picked up - I don't know how factual it is and I've never seen anybody do this.
Old Mar 22, 2017 | 01:06 PM
tuxnharley's Avatar
tuxnharley
Quartz movement here - 20 years +.
Old Mar 22, 2017 | 04:30 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The old Borg movements were always an issue based on the design of the movement. The point contact electromagnetic reset mechanism was a very poor design and the points were susceptible to burning. They are very fix-able and sometimes you get years out of them, other times you get way less. The 63 Coupe we did three years ago is still ticking strong today.. If the car is not being shown or judged your best bet is to install a quartz movement.
-Willcox
Old Mar 22, 2017 | 04:34 PM
Frankie the Fink
Army
-Willcox
I agree completely and before anybody asks I know of no quartz movement that will tick like an original.
Old Mar 22, 2017 | 04:52 PM
vettepoor's Avatar
vettepoor
Active Streak: 90 Days
I remember the clock in my 65 being finicky about running. I had to constantly "tweak" the stem to get it to run, but it would quit after a day or two. Finally shot innards with WD40, and it never missed a beat for next 8 years until I sold it! This was in 1973, when WD40 was widely thought of as being a cure-all for any mechanical movement. I had my 57's clock cleaned by a pro, and it still keeps perfect time for 14 years now.
Old Mar 22, 2017 | 04:59 PM
Renwaltoys's Avatar
Renwaltoys
Thanks very much for the diagram and the article, Duke
Old Mar 22, 2017 | 08:14 PM
65GGvert's Avatar
65GGvert
History has shown that a rebuilt C2 clock will work after rebuild somewhere between a few minutes and several years.
Old Mar 22, 2017 | 08:19 PM
65GGvert's Avatar
65GGvert
Now you won't ever have to type that again:
http://licorvette.com/clock%2065%206...20corvette.htm
https://willcoxcorvette.com/corvette...assembly-65-67
Amazon Amazon
Old Mar 22, 2017 | 08:31 PM
USMC 0802's Avatar
USMC 0802
Veteran: Marine Corps
USMC
My father updated my 66 to quartz movement in the 80s and its still going and keeps perfect time....
Old Mar 22, 2017 | 08:39 PM
Frankie the Fink
Army
I should have qualified my statement; it may possibly tick (after a fashion). Here is what Clock Works has on their web site; with all respect; I'll just keep on typin' :
Old Mar 22, 2017 | 08:44 PM
65GGvert's Avatar
65GGvert
That says C3
toddalin's Avatar
toddalin
I think I had the original clock movement cleaned in the '80s when I had the gauges redone and it still works like new..., and "tinks."
To C2 clocks
Old Mar 22, 2017 | 08:46 PM
Frankie the Fink
Army
Originally Posted by 65GGvert
That says C3
True but I think its a general statement based on the rest of that web page. At any rate, if somebody wants their clock to pass judging Click Works will put in an OEM Borg movement for $150...
I'll stop typing now
Old Mar 22, 2017 | 09:03 PM
65GGvert's Avatar
65GGvert
Even if they now click, I bet they don't "clunk".
Old Mar 23, 2017 | 01:42 AM
1969RAY's Avatar
1969RAY
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
C2 of Year Finalist (appearance mods) 2019
Master of the obvious here--but the main reason that they quit is dust in the movement. That's why WD40 works. So seal the seams with RTV and it will extend the life-
