[C2] Recommendations Mini Starter
Old Apr 9, 2017 | 09:21 AM
65tripleblack's Avatar
65tripleblack
Default Recommendations Mini Starter
Steel QuickTime belly housing only works with mini starter.
*&%##$^*^)_)_(^%$$%^&*|+_||())*!!!!!!!!! !!!
How about this one?
Summit hi torque mini starter: $112.00
Experiences? Junk or OK?
Will my Corvette sound like a MoPar from now on when I start it?
Last edited by 65tripleblack; Apr 10, 2017 at 09:12 AM. Reason: Add name of starter
Old Apr 9, 2017 | 09:38 AM
j_66chevelle's Avatar
j_66chevelle
I'm using a quicktime Tilton makes great starters, expensive 3-400
Old Apr 9, 2017 | 09:39 AM
RJ1's Avatar
RJ1
How about this one? Experiences? Junk or OK?
I have had a Hitachi PSL 100 mini for years. Great and doesn't sound like a MoPar!!
Old Apr 9, 2017 | 10:33 AM
Tom Austin's Avatar
Tom Austin
Is this the one you're running? I also have a mini starter on my '66 and it's failed over the past 2 weeks - need to shop for a new one!
http://www.ebay.com/itm/Hitachi-Enfo...5UajhK&vxp=mtr
Thanks!
Tom
Old Apr 9, 2017 | 10:42 AM
TJefferson2020's Avatar
TJefferson2020
I bought a Summit Racing one 10 years ago and it is one of the best mods I've made. Spins my small block like a jet engine.
I have the original starter too if somebody wants it. It works but it's too big for my set up and, like all GM starters does not like header heat. When I built more power in to my motor, it increased temperatures and the starter started getting flaky. Under normal conditions, the GM ones are pretty bullet proof. But power plus headers? Not so much.
Old Apr 9, 2017 | 12:52 PM
RJ1's Avatar
RJ1
Thanks!
Tom
Tom appears to be the same starter but never saw the Enforcer on the one I have. Mine has been on the car for 6 years no problem. It was just PSL 100 super lite on the invoice. Price is same.
Old Apr 10, 2017 | 09:13 AM
65tripleblack
In original post I originally added a web address. Either I'm getting senile or it was edited out.
In place of that I added the name of the unit I'd like to use:
Summit brand mini starter. $112.00.
Old Apr 11, 2017 | 03:25 AM
rnixon's Avatar
rnixon
C2 of Year Finalist (appearance mods) 2019
If you want the best, check out Meziere Enterprises, but make sure you're sitting down when you look at the prices.
Old Apr 11, 2017 | 11:05 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I bought a basic one from summit about 17 years ago and it's still working fine on my 555. It's a nippondenso design which is good stuff. Easy to repair if you ever needed to but not likely. Mine has a multi position plate where you can rotate it to several positions to clear headers and oil pans.
Jim
Old Apr 11, 2017 | 11:15 AM
Mikado463's Avatar
Mikado463
nothing wrong with that, after all they (MoPar) pioneered the gear reduction starter.........
Old Apr 11, 2017 | 12:48 PM
65tripleblack
Jim
Is the one you have similar to the one I'm looking at?
Summit shows three categories (styles) for "mini" starters:
1. Denso (Nippondenso)
2. Hitachi
3. Mini
I don't know whether these are brand names, or actual "styles". The one I'm looking at is listed as a mini":
https://www.summitracing.com/parts/s...make/chevrolet
Old Apr 11, 2017 | 01:50 PM
RJ1's Avatar
RJ1
2. Hitachi
3. Mini
Denso and Hitachi are brand names. Looks like the Mini is made for Summit Racing's product name.
Old Apr 11, 2017 | 01:56 PM
Mikado463's Avatar
Mikado463
I used a PowerMaster in my 12:1 462ci motor that was in my '86 Monte, never let me down.......
http://www.jegs.com/i/Powermaster/71...FdSCswodf5YJqg
Old Apr 11, 2017 | 06:44 PM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Jim
I have essentially the same thing on the W30 spec 468 Olds in the Cutlass with a Richmond 5sp. It's been on there for about 7yrs. ZERO issues and yes, it does sound kind of like a Mopar starter.
I got mine from these guys. http://www.hitorque.com/
Old Apr 11, 2017 | 07:09 PM
65tripleblack
Update to Summit website. Conflicting information:
If you go to the page listing ALL the starters for a SBC, then the one I'm considering is listed as "Mini". BUT, if you click on the starter I'm considering then it's shown as a HITACHI, which is good stuff. I'll ask their techie which is correct.
I get the impression that "style" means "brand" with "mini" meaning all other manufacturers except Hitachi and Nippondenso ("Denso").
The one I'm considering gets all good reviews and looks like good bang for the buck. So, I'm becoming firmer in my choice now. The only thing I don't like about it is that I'll have to cut the "S" connector off my harness and replace it with a spade connector.
The instructions also mention the likelihood that multiple shims might be needed for fitment to engines originally using an iron nose (old) starter. Anybody here have that issue? The starter comes with 2 shims and I'm thinking I might need more.
I have no ballast resistor so (according to the instructions) I don't need the "R" terminal...................I'll just tape off the "R" wire. I have to check the wiring on my car to see whether this is true, or not.
I don't yet see why some guys use a remote solenoid with these starters.
Old Apr 12, 2017 | 04:10 PM
steampunk c1's Avatar
steampunk c1
Add a relay into the starter wire to increase voltage to starter solenoid.
Old Apr 12, 2017 | 05:59 PM
427Hotrod's Avatar
427Hotrod
This is the type I use.
https://www.summitracing.com/parts/sum-820323/overview/
JIM
Old Apr 12, 2017 | 07:03 PM
63Corvette's Avatar
63Corvette
I have heeaders, so I have been using a Tilton (mini) starter since 1980 without problems. It has outlasted many engines
To Recommendations Mini Starter
