Modify a '54 hood
Old May 8, 2017 | 09:35 AM
DAN70's Avatar
DAN70
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Default Modify a '54 hood
This wasn't unexpected, I have a 283 with 2x4's in my '54 and naturally the hood will not close. Will removing part of the X brace be sufficient to close the hood? I'm sure this has been done before. I'd rather not use a hood scoop....
Old May 8, 2017 | 10:12 AM
csherman's Avatar
csherman
2026 Corvette of the Year Winner - Unmodified
2025 C1 of the Year - Unmodified Winner
2019 C1 of Year Finalist (stock)
2018 C1 of Year Finalist
I thought you would have issues. I mentioned it a while back.
Please dont cut a good OE hood.....
Ever think about a 56/57 hood - the bracing is different
Or a 54 hood already cut for a carb and hood scoop ( I have one)
Old May 8, 2017 | 10:14 AM
ohiovet's Avatar
ohiovet
2016 C1 of Year Finalist
I had a early 54 with a 305 V8 in it with a carb, hood closed perfectly.
Don't ruin a perfectly good hood by cutting it.
Probably need a different intake or modify the front mounts (THIN THE RUBBER BUSHINGS) to lower the engine.
Or worst case just carefully cut the bracing and save the pieces.
Bruce B
Old May 8, 2017 | 10:54 AM
DAN70's Avatar
DAN70
Yep, you did. I knew I'd have a problem. I don't want to butcher a good hood. I don't want a scoop either. I've seen these cars with V-8's, and the stock hood but never inquired about it.
56/57 hoods have a diffent look.
Old May 8, 2017 | 10:59 AM
DAN70's Avatar
DAN70
Bruce B
It's a Corvette 2X4 intake and carbs, doesn't get much lower then that.
Looks like just the center of the X is all that needs to be removed.
Old May 8, 2017 | 11:01 AM
csherman's Avatar
csherman
yeah - the 56 57 have the "power" bulges up the sides
- shorter air cleaners?
- how much clearance with the air cleaners off?
- cut the motor mount bushings
Old May 8, 2017 | 11:06 AM
DAN70's Avatar
DAN70
I'm using these air cleaners....
Old May 8, 2017 | 11:08 AM
DAN70's Avatar
DAN70
What's the difference between my 54 and a 56/57? Motor wise....
Old May 8, 2017 | 11:14 AM
csherman's Avatar
csherman
you mean 55 - with a 265?
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
54 motor:
Old May 8, 2017 | 11:17 AM
DAN70's Avatar
DAN70
Yes, exactly... Is it just the 2X4's. They worked on the 56/57.
Old May 8, 2017 | 11:19 AM
DAN70's Avatar
DAN70
Originally Posted by Chuck Gongloff
54 motor:
....NICE....o
Old May 8, 2017 | 11:23 AM
Chuck Gongloff
....NICE....o
The inner surface of the 55 hood is different. I couldn't find a picture.
IIRC, there is no X brace on the 55 hood.
Old May 8, 2017 | 11:24 AM
csherman's Avatar
csherman
because the hood is different - there is no X brace - there is a brace across the hood - right in front of the first carb.
Same for 55's with a v8 - no x brace - this is the reason you see so many 53 and 54's with holes cut in the hood for carbs - mine included.....
Old May 8, 2017 | 11:31 AM
DAN70's Avatar
DAN70
Then why cut a hole? Just remove the X. Right.
Old May 8, 2017 | 11:52 AM
Chuck Gongloff
Also, and IIRC, there is a different type of reinforcement. Wish I could find a picture.
Old May 10, 2017 | 11:48 AM
csherman's Avatar
csherman
here is a hood already cut......
strip it and repaint it....
http://www.ebay.com/itm/1953-1955-Co...FZA5HP&vxp=mtr
Old May 10, 2017 | 01:29 PM
ohiovet's Avatar
ohiovet
It looks like you could drop an engine in through the hole in the hood.
Old May 10, 2017 | 01:46 PM
csherman's Avatar
csherman
big blower.......(that is what she said)
To Modify a '54 hood
