Between driving the car and everything else, the engine compartment has gotten really dusty and dirty. I need to clean it. First thought was a power washer but that might be too much. Next I considered one of those gizmos that you attach to your air compressor that sprays pressurized water at 90 psi. What do you folks think ???
No pressure washing. Just use mild cleaners and rags. Take one section at a time, get it clean, and then move on to another part. It may take a few sessions to get it the way you want it to be.
As a professional mechanic, the only time I would pressure wash an engine compartment is when the engine is removed from the car, period. Pressure washing the engine itself is a bad idea. What the others said: simple green or solvent, and rags, and an area at a time.
I prefer 50/50 Shout It Out/water to Simple Green. Very gentle on all paint and metal treatments. I use a bug sprayer. Spray on, let sit for 5-10 minutes and rinse. I also use a small electric pressure washer when I'm not nervous about electrical connectors (diesels, dirt bikes).
A pressure washer is a bit too much for a restored car. It can knock off electric connections and lift paint. (not to mention the corrosion that will follow because it doesn't have a coating of grease on it.)
I have a 2002 that I bought new and have never even thought of washing the engine comp.
My 32 roadster, however, gets washed with mild detergent and a hose each time I wash the car
