pissing match with body man! paint or no paint!
C2 of Year Finalist (stock) 2019
well my body man has been getting kinda pissy about what should be painted and not on my 65 roadster.. here is the latest one, so i believe the inside floor, and underside does not get paint, just bare glass? he swears up and down that a low miles 63 coupe he did in the late 70s had painted floors and underside, and he was the first too touch the car for paint work? these debates have been going on with several other things on the car also. i think its just a distraction, to sit back and drink coffee on his part! so fill me in here guys who is right? thanks troy
Popular Reply
05-16-2017, 07:23 PM
Received 1,857 Likes
Simple general rule - any clips/brackets that are RIVETED to fiberglass were installed in the Body Shop, prior to body paint; if they're attached with screws or bolt/nut mechanical fasteners, they were installed AFTER body paint.
Received 2,827 Likes
Crowd Plow For Now
Far as I know - you are right. No paint Ask Frankie
Received 6,943 Likes
2015 C2 of Year Finalist
The pilot line cars got the complete underside blacked out as seen in the Adams book. However ALL PRODUCTION cars got bare glass on the floor pans. the only black out is the wheel wells and the sides of the jack stowage area that is seen through the wheel wells
20round (05-16-2017)
Sounds like your body/paint man does not want your job. Because that's where your conversation with him is headed, if I were you.
I would tell him like Lt. Bullitt above said,
"do my job the way I tell you to do it, or say adios to this job."
Just as simple as that.
ptjsk (05-16-2017)
Maybe your paint guy is thinking about the body color overspray that may have been on the inside floors from painting the air intake grills from the cowl. They were placed on the cars floor to be painted.
Received 1,901 Likes
Seems like there is a lot of tension between the two of you, and he hasn't even painted the car yet.
I can almost guarantee that there will be problems looming ahead, probably even more so after color is applied.
If it were me, I would be showing up at the opening hour of the next business day. And I would be pulling an empty trailer, which would have my car in it on when I left.
Bottom line is that you're the customer spending your money to get the car completed the way you want it to be.
A good business man would be able to get his point across, yet still follow the instructions of the paying customer.
Pat
Pat
Stan's Customs (05-16-2017)
Received 3,443 Likes
Pat
Pat
There is a ton of controversy about 63 "blackout" but not much about body color. My 63 May car has extensive blackout at the rear but NO body color or blackout on the floor pans. Bare blonde fiberglass. I think your paint guy is full of it.
Its a bad scene when you get sideways with somebody working on your car. You have to wonder if he'll stand by any warranty issues should they arise if you force him to do something he thinks is incorrect.
thank you nowhere man! another Q for you since i have your attention for a min. the driver inner fender washer bag bracket, and wire loom clips in the front on both inners along with the catch can bracket, do they get painted in place or where they added after paint? thanks
Bracket before paint I think. The wire looms defiantly after paint
If you aren't ready to leave your paint and body guy you could compromise and have him cover the underside and floor with flat clear. It does help cleanup. Just thinking outside the box.
St. Jude Donor '05, '09, '15
Pat
Pat
Just went through a miserable ordeal with a body shop. 1 1/2 years of hassle. Get out before you have too much money invested with him and can't get out.
Tom
