[C1] Battery on a '61
Battery on a '61
Anyone know where I can find a photo of an installed battery on a '61? Just curious how the positive battery cable is isolated from the metal hold down bracket. The felt washer doesn't seem to be large enough to completely isolate it. I guess I could stick a piece of rubber between the battery terminal and the hold down if I have to.
If you have an owners manual there is a diagram of an installed battery and cable unit. Also under the + terminal of the battery you should have a felt washer that acts as an insulator. Myself I routed the cables across the battery so that the battery cable ends ended on the inside area of the battery.
Received 1,295 Likes
2022 C1 of the Year Finalist - Unmodified
2021 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Modern batteries have different spacing on the terminals.
It does clear but it makes me a little nervous too.
I would NOT trust a felt washer for electrical isolation.
Here is a photo of mine
Split a rubber fuel line and push it on along the battery cover rail. Done.
That is just the color coding on some cables; note the "P" on the clamp itself...
I'm not crazy about it either....you have to double check things when connecting cables or jump starting the car...
Frankie is right. The ground wire is a braided metal cable with no jacket.
I believe these are correct... but I'm not a NCRS-type.
