Shifter install problem
Old May 29, 2017 | 12:21 PM
Mikey Hawks's Avatar
Mikey Hawks
Default Shifter install problem
1964 327-300 4 speed with a muncie shifter.
Trying to reinstall my stock muncie shifter I ran into a problem. When I attach the linkage and go inside to bolt the shifter to the trans, the shift handle is pointing all the way back (like toward 2 or 4 gear) nearly touching the tunnel.
I did everything I was supposed to do, put the trans in neutral, put the shifter in neutral and used my home made tool to keep it in place, I even read old posts that describe how to do it. From the posts, it appears I'm doing right but I end up in the same position every time. I feel like I'm missing something.
BTW, I installed the shifter the same was once before and had no issue. Is it a case of trial and error or am I doing something wrong.
Thanks for the help.
Old May 29, 2017 | 12:23 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
do you have the shifter assembly bolted to the right set of holes on the side of the tailshaft housing?
Bill
MelWff's Avatar
MelWff
bolt the shifter up first and attach the linkage after so the linkage can be moved out of the way if I'm understanding your problem correctly
Old May 29, 2017 | 12:39 PM
Mikey Hawks
I have the shifter bolted in but there was only one bolt when I took it out.
Like I stated above, when I connect the linkage to the trans, the shifter is all the way down and it doesn't shift at all.
Old May 29, 2017 | 12:41 PM
Mikey Hawks
Bill, the last 2 holes on the tail are for the shifter housing?
Old May 29, 2017 | 01:15 PM
Vet65te's Avatar
Vet65te
If you're using the early triangular mount plate, it's the last three holes, two on top, one at the bottom.
Mike T - Prescott AZ
Old May 29, 2017 | 01:40 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
last 3 holes, per pictures in post 6
Bill
To Shifter install problem
