[C1] C1 Cooling question
First off - I would LOVE to buy the Dewitt's aluminum radiator, but it's not currently in the budget. Also, I have read where there should be no gaps in the fan shroud. As you can see in the pictures, I definitely have gaps. The question is, what is the best filler for those? Do I have to buy a kit specifically designed for these (this car is not NCRS) or is there an effective alternative?
I've also read that the fan should be situated inside the fan shroud, but I only have about 1 inch between the fan clutch and the sway bar. How for should it be inside?
Lastly, I have considered putting a 14" electric fan on the inside of the radiator. Will that work? I'm not sure how it will interact with the steel fan, which I would like to leave on the car.
I'm giving this car back to my Dad next month and want to ensure he does not have any major issues with it. Any advice would be greatly appreciated!
Jim
Thanks for the advise. I will probably use the high density foam as you recommend. It seems like it would be easy to trim so that it still looks good. I will definitely get the Dewitt's eventually, but I'm down to four weeks before I give the car back, so it will unfortunately have to wait. The seven blade fan sounds like an option too, as long as I can find a steel one; I'm trying to keep it as original looking as possible.
Thanks again!
Jim
https://www.summitracing.com/parts/sum-g4953
I will pick up that spacer today. I will make sure that foam is glued well also - great tip.
Thanks,
Jim
The first pic is my fan with a spacer in place of the fan clutch and pipe foam along the top and down each side works splendidly!
There should also be a rubber seal along the front of the lower edge at the radiator and a triangular rubber seal at each corner in the front...you can make them out of old floor mats, rubber tool box liner or buy repros.
I read earlier that the timing could cause over-heating problems. I do plan on checking that.
Thanks again,
Jim
Thanks very much for the input. Frankie, that insulation looks great - I will pick some up and give it a shot. I've should be able to get the spacer installed tomorrow. I just need to decide on fan clutch or no fan clutch. Decisions, decisions......
In front of the radiator I have a rubber cover around the edges of the radiator keeping any air from going around the radiator. i also use fiberglass screening to keep the bugs and cotton wood out.
How do we know you are running hot?
The odds are you have already done this, and thus need to work with the excellent suggestions so far, But if not, here is the next key step:
Buy an infrared temperature scanner.
The stock temperature gauges and senders on these cars are notoriously inaccurate. How bad? There are even inline resistors that are sold to correct the situation:
http://www.parts123.com/corvettecent...50e&ukey=30980
A personal example: I ran a 7300 FI unit on my 57 for 25 years. Never ran hot. Then I decided to convert to correct dual quad set up for my car. Ran 220 right out of the box. Being a racer, I immediately checked all the stuff that could have changed with what I did- timing, proper air/fuel ratio, etc- no difference. Then I researched the forum, and found all the complaints about the inaccurate senders and gauges. So I got my trusty infrared temp scanner out of my toolbox that I use for tire temps at the track. Radiator hose near thermostat? 178 degrees. Thermostat housing? 181 degrees? Radiator? 175 degrees. My car wasn't running hot- the sender/gauge combo just sucked. So I installed the resistor above, and now I trust what I see on the gauge.
If this doesn't help, my apologies, and I defer to the experts. But hopefully it will help some newbie from pulling their hair out
Good luck!
Marc in Indy
This is NOT the correct reproduction but rather a replacement radiator from our Direct Fit line. This is a double row core with standard end tanks. We even use the same cast necks as the restoration radiator so it looks real nice in there with the Black Ice option.
Link to page
That DeWitt's radiator looks outstanding, I'm definitely going to check it out.
Thanks again!
Thanks again!
As far as temperature variations, mine reads about 40 lower than it should. But that is on a newer GM crate motor.
