[C2] Engine Upgrade
Old May 26, 2018 | 12:19 AM
  #201
bdhulderman's Avatar
bdhulderman
Ok, I found out my Fitech Meanstreet 800 fuel pressure regulator went out on me, so I'm having to put in my own inline regulator. The good news is, I can now block off the return line on the Fitech, and instead use that return for my regulator and bring it up to 58 psi, instead of the 43 that the Meanstreet 800 was internally regulated at, giving me fuel delivery up to 1000 Hp.
https://www.summitracing.com/parts/aei-13301
The other day I recorded the idle after some tuning for idle quality. This camshaft, with just 5 in Hg, needs to be set with the EFI to over 16 AFR at idle, because the oxygen sensor is also reading the oxygen from the overlap in the cam, in order to keep the plugs from fouling out. Plugs look great at idle with this idle setting. After 1200 rpm, it starts to richen to 12.5 at WOT for max power.
Old Jul 2, 2018 | 08:49 PM
  #202
bdhulderman
Default Hurst Line-Lock Installation Test
Here's my baby burnout I did with my new line lock system I installed. Worked great to lock the front wheels.
https://www.summitracing.com/parts/huu-5671518
I just didn't want to eat up my new $100 tires on the street. My wife apparently gets a little nervous. LOL
Old Jul 3, 2018 | 10:31 AM
  #203
reno stallion's Avatar
reno stallion
C2 of Year Finalist (appearance mods) 2019
I bet your neighbors love you
Old Jul 3, 2018 | 05:51 PM
  #204
bdhulderman
Yeah, the little kids that live there loved it.
Old Aug 5, 2018 | 11:11 PM
  #205
bdhulderman
I couldn't resist putting the toon of my car I had done to put on my arm. It's looking really angry right now before it's had a chance to heal. I love it!
Can you tell I"m in love with my '66?
Old Aug 6, 2018 | 08:35 AM
  #206
Vortecpro's Avatar
Vortecpro
Very nice. Lets get this to the drag strip....
Old Aug 6, 2018 | 08:56 AM
  #207
cv67's Avatar
cv67
St. Jude Donor '05
Yep, you get what you pay for. Looks nice and clean though.
LOL different strokes....LS3 is a very nice motor for sure...nothing compares to raw cubes though!
That is going to kick arze...shaft rockers Im assuming? which heads?
Think youll be fine wiht a tight ring pack, good machining is everything.
The LS has been using them forever they last forever. I dont see anyone using the old thick iron stuff anymore.
tpi421vette is running a 46x?? sbc runs 9s on it with a much smaller cam, 245 heads. Ought to have a rocketship on your hands.
Old Aug 6, 2018 | 09:35 AM
  #208
bdhulderman
T&D Shaft Rockers, full roller solid cam, AFR 235 heads. Can't wait to get it to the track.
