Antifreeze
Old Jul 8, 2017 | 05:03 PM
ditchdigger650's Avatar
ditchdigger650
Default Antifreeze
Hi folks, I'm about to drain my radiator and was wondering what brand antifreeze do you use on your aluminum radiator. I have the stock L-79 motor, I drained it some time ago and forgot the actual brand I used. Just wondering what you guys recommend. I have DEX-COOL running in my Silverado, could I use that? Thanks, Gary
Old Jul 8, 2017 | 05:13 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
DO NOT USE DEX-COOL. just a 50/50 mix of green and distilled water
Old Jul 8, 2017 | 05:25 PM
Mike67nv's Avatar
Mike67nv
2018 C2 of Year Finalist
2015 C2 of the Year Finalist
Like Nowhere Man says, don’t us Dexcool, it will leach the lead out of soldered joints (heater core). The green stuff, like Prestone is OK, but I strongly recommend Zerex G0-5 (yellow or amber), it’s an HOAT coolant, and has a more effective additive package for protection of aluminum radiators.
Old Jul 8, 2017 | 05:34 PM
Tmichaelson's Avatar
Tmichaelson
Default Xerox GO5???
Prior CF discussion led me to believe ZEREX GO5 antifreeze was the preferred one for aluminum radiators or is that just true for Dewitt's radiators??
Old Jul 8, 2017 | 05:38 PM
Nowhere Man
Well stock OEM radiators are aluminum. So yeah.
Mike67nv's Avatar
Mike67nv
It would be preferred for all aluminum radiators.
Old Jul 8, 2017 | 06:31 PM
RatDog's Avatar
RatDog
St. Jude Donor '20 thru '25
I use Zerex G-05 in my original L79 with Dewitt's radiator. 50/50 mix with distilled water.
Steve
Old Jul 8, 2017 | 07:54 PM
GTOguy's Avatar
GTOguy
The normal green stuff, mixed 50/50 with distilled water. I can't begin to count the catastrophic cooling system failures I've seen over the past 20 years caused by Dexcool. I wouldn't use it as weed killer.
Old Jul 8, 2017 | 08:09 PM
ditchdigger650
Ok fellas, I'll try the Zerex. Thank you for all your help.
Gary.
Old Jul 9, 2017 | 09:07 AM
427/42566 coup's Avatar
427/42566 coup
don't forget to drain the block. Still lot's of coolant still left in bottom of block.
To Antifreeze
