Well, a stock shroud is bonded together in pieces but, whether it's stock or a replacement it will be in ONE piece.
like Nowhere Man said/asked, removing the fan clutch and fan SHOULD give you enough room however, it's sometimes easiest to just disconnect both radiator hoses and R&R the radiator and shroud as a unit.
Gary
would you be kind enough to attach a picture of the weather stripping you attached to the shroud.
