[C2] Where can I buy this disconnect switch
#41
Here's mine, and yes it is connected to positive. That way I can hook up my fuzed quartz clock and radio to the switch instead of the battery terminal. When I turn off the switch the clock still runs and my radio doesn't lose its preset stations.
#42
St. Jude Donor '07
Bill
#44
Received 1,581 Likes
St. Jude Donor '20-'21-'22-'23-'24
I've also forgotten to connect power more than once before trying to start the the car and had to replace the fuse. My Hella red key is inside my glove box and I have the fuse holder tucked under the glove box so the fuse is easy to change.
Steve
#45
The round **** you have to tighten to get contact and my experience is that tightness increases over time as you keep torquing on it and then eventually you can't get it tight enough to make contact.
To test the round **** switch; throw it into any convenient large body of water as far as you can. If it floats its good, if it sinks its bad
#47
Much easier to push a Button inside the car On and Off....
http://www.painlessperformance.com/Manuals/30206.pdf
But What ever floats your boat.
#48
One reason I Use this....
#49
Cole hersee 24200 is another latching solenoid option.....$40 on Amazon.
#50
If you want to step it up you can buy a remote disconnect. Then you have a key fob with two buttons, one to connect and the other to disconnect. Kinda nice. you don't even have to open the hood.
#51
Similar to a Starter Solenoid as you stated.
Only power is drawn when you push the button and release.Then It's off.
Lose your Key Fob on the wireless ones and your SOL. The switch on this one can be hidden in the car. You won't lose that
