C1 help
Old Jul 16, 2017 | 10:58 AM
reno stallion's Avatar
reno stallion
C2 of Year Finalist (appearance mods) 2019
Default C1 help
Dose any one know how to get these c1 turn signal connectors apart?
Old Jul 16, 2017 | 11:10 AM
prestige6's Avatar
prestige6
They are two separate connectors that come apart Lift up the prong in the middle and pull apart..
Old Jul 16, 2017 | 11:23 AM
reno stallion
they seem to be one piece no prong
Old Jul 16, 2017 | 11:36 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
look into the ends of the connector housing
Bill
Old Jul 16, 2017 | 11:46 AM
GEM '62's Avatar
GEM '62
Those are one piece connectors. They don't come apart. You can remove the wire and lug by using a thin piece of shim stock pushed along side of the lug. Kind of a PITA job but I have done it a number of times. Most times you can't find new lugs that fit the connector so you have to reuse the old ones, even more of a PITA.
Old Jul 16, 2017 | 12:22 PM
reno stallion
I have this nifty little tool but still wont come apart
Old Jul 16, 2017 | 12:34 PM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Get some needle nose pliers.
Reach into the turn signal end of the connector, and grab the end of the brass connector and pull, one by one. The male ends you are grabbing, have no tang, to my recollection, only the female ends do, which keeps them in the plastic housing.
Doug
Old Jul 16, 2017 | 12:35 PM
GEM '62's Avatar
GEM '62
The lug has a little protruding punch out that catches the plastic lip inside the connector. You normally have to enter the connector from the opposite side that the lug is installed from. You should be able to look into the connector and see what you need to do. You can also slide a small, very thin screw drive in and flatten the lug so it will pass the connector lip. PITA
Old Jul 16, 2017 | 12:47 PM
reno stallion
PITA is correct
Old Jul 16, 2017 | 01:03 PM
DZVette's Avatar
DZVette
As others have pointed out, run a thin tool into the connector to depress the locking tab and pull the connector out from the rear. See attached PDF.
DZ
File Type: pdf
Old Jul 16, 2017 | 03:13 PM
buns's Avatar
buns
For some reason DZ's PDF didn't show how to unlatch the male terminal. This is how it is done.
Also, several sources for the terminals:
https://theelectricaldepot.com/weath...8402e360685a29
http://terminalsupplyco.com/Store/De...228#Categories
http://www.repairconnector.com/packa...-and-housings/
Old Jul 17, 2017 | 01:54 PM
DZVette's Avatar
DZVette
Thanks Tim!
Good video here:
DZ
Old Jul 17, 2017 | 07:25 PM
plaidside's Avatar
plaidside
To remove the wire on the switch side, pull on the wire termianl with a needle noose pliers and it will pull out of the connector.
Here is the 'tool' I use, just an old small bladed screwdriver that I ground down thin at the end.
Now while pushing the wire into the connector, insert the flat thin screwdriver into the slot until it bottoms, sometimes you have to slightly turn the screwdriver to disengage the tang. The red arrow is the slot and the black arrows are the tang.
Before inserting back into the connector I gently bend the tang up slightly. Just push it into the connector making sure the tang is in the slot until you hear a click.
Now insert the male teminal/wire completely into the female connector.
Old Jul 18, 2017 | 09:45 AM
reno stallion
Default Thanks
Thanks for all the good info and pics. Here's what my 58 male connecters look like.
Old Jul 18, 2017 | 05:21 PM
DZVette's Avatar
DZVette
Reno
Those are like the ones I found with my LL rear body harness. If I recall, I just plugged them into the connector from the dash harness that is shown in the photo below.
Based on the wire colors you show, I think you are looking at the same connection.
Hope this helps a bit.
Dave Z
To C1 help
