C1 water pump brand question
Old Jul 22, 2017 | 07:50 PM
tach drive 61's Avatar
tach drive 61
Default C1 water pump brand question
again just getting opinions on a water pump brand , short steel replacement brands. I hate to admit it but if memory serve's me correct the last one was bought at pep boys , it has lasted well over eight years , on the current engine removal there is no way the working when removed one will be put back ! edlebrock aluminum one failed prior to my ownership use
Old Jul 22, 2017 | 08:24 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
I had to use a VERY expensive Edelbrock because of the timing cover on my ZZ4. personally, in your situation, I would use whatever my FLAPS has....
Bill
Bill
Old Jul 22, 2017 | 09:41 PM
GCD1962's Avatar
GCD1962
Just bought a new one from Rock Auto for my '57 Belair. Paid about $18.50. Quality and fit was excellent. Well made item.
Old Jul 22, 2017 | 10:21 PM
Randy G.'s Avatar
Randy G.
Napa for me.
Old Jul 24, 2017 | 01:45 PM
solidaxel's Avatar
solidaxel
Stewart Components on all 3 of my SBC two are ZZ 4
I just changed one that had 73K miles, small leak !
Old Jul 24, 2017 | 02:42 PM
GTOguy's Avatar
GTOguy
I bought mine from NAPA for my '61. The flanges were way beefier with more material where the pump meets the block on the NAPA pump than on the GM pump I removed. Very important when the pump is part of the motor mount!! No leaks with this one.
Old Aug 6, 2017 | 01:32 PM
tach drive 61
I now remember the last one I bought was a bosch ! from its bearing weep hole its flowing out oil or grease it made 7 years , looks like I will be using the Gates standard pump this time around , had another new one here in my stash but it a really sad looking Chinese pump ,
If I don't like the look of the Gates Ill try Napa . Thanks everyone for input !I also will use Indian head on sealing gaskets & new bolt kit !
Old Aug 7, 2017 | 01:37 PM
tach drive 61
Times have changed I see CHINA made in China this morning the gates pump arrived , and there it was a long style made in china pump boxed wrong ! then went and bought a Napa: pump , same part # on box ,
while installing the vertical 90 degree I hear a ping , lucky my hearing still exists , the housing cracked , so looks like todays rainy day installation on the 61 motor will be put off again !
Old Aug 7, 2017 | 01:46 PM
GTOguy's Avatar
GTOguy
Indian Head shellac is the last thing I would use on the gaskets....It sets up hard. You want to use NON HARDENING Permatex number 2. Ask any of the old C1 guys. Use it on the bolt threads too. Also, didn't catch it the first time, but I would never run an aluminum pump on these cars....it's the engine mount too, remember. Plus, aluminum and iron have different expansion rates, testing an already failure-prone design even further.
Old Aug 7, 2017 | 01:54 PM
tach drive 61
I will not use the Indian head , when I bought the car it had a alum pump it failed , later on ill have a second cast napa pump and with caution install the hose fittings , I have the # 2 permatex as well standing by ! thanks
To C1 water pump brand question
