1954 Spare tire tub
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
1954 Spare tire tub
We'll, I have 300 trouble free miles on my '54.
Over the last two years I've done a frame/drivetrain restoration and it turned out pretty good except for a problem I noticed yesterday when I had it on the lift. The rear differential is hitting the spare tire tub. I put new springs from Paragon and new shocks that's the only change I made. When I lowered the body onto the frame everything lined up perfectly. So, any ideas why this is happening? Thanks....
Having has about 7 of the 54 Vettes I have not a clue why you are having this trouble but I did send the link to the thread to a couple guys who may be able to help you. Hang in there, one or both will reply I am sure.
DAN70 (07-23-2017)
DAN70 (07-24-2017)
I know it doesn't help in your situation, but I thought I would pass on my experience. I had the same problem, but worse, on my 55. The body had never been off the frame. When I removed the rear leaf springs I founded the center bolt on both springs had sheared which I believe allowed the rear axle to shift backwards against the tire tub. I can't think any other explanation.
I had the springs re arched and reinstalled which so far looks ok.
DAN70 (07-24-2017)
