Vent window problem
Old Aug 10, 2017 | 01:03 PM
macs65's Avatar
macs65
Default Vent window problem
Had the vent window frames removed a few years ago, re-chromed and new weather strips installed. since that time the vent windows have not closed properly. they crank closed to the weather strip at the top of the vertical bar but must be forced in by hand.
The short horizontal frame at the top of the window appears to have a 1/32 to 1/16th of an inch space between the frame and the weather strip which stops the window from closing all the way. Are these vent windows adjustable??
Thanks foe any help.
Old Aug 10, 2017 | 01:13 PM
Jackfit's Avatar
Jackfit
You are not alone....new weather strip does not fit properly..I do not open my windows anymore...I have to use a tool to help close the window..I only did one side...and left the old weather strip on the other window.
The whole unit is adjustable , and must be done with the door panel off. there are bolts the allow the whole unit to move up down and forward...however,,,,the vent window is not adjustable in the frame.
You may have to trim the rubber to get it to close....be careful..
Jack
Old Aug 10, 2017 | 01:38 PM
vettsplit 63's Avatar
vettsplit 63
From: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
Jack
What he said...
Old Aug 10, 2017 | 08:53 PM
KENS78SILVERANNIV's Avatar
KENS78SILVERANNIV
Had a similar problem after installing new rubber around the vent windows. Wouldn't close properly. Turned out the weatherstripping wasn't the issue. It was the regulators. Installed new ones...problem gone.
Old Aug 11, 2017 | 02:14 PM
DansYellow66's Avatar
DansYellow66
It helps to lube up the window weatherstripping with something like silicon grease and push the window into the seal all the way and let it sit there for a few months until the rubber relaxes. But depending on the rubber and how far out it is, it may not help. Regulators in good shape are definitely a help if you plan to use them.
Old Aug 11, 2017 | 04:39 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
I know my 63 has repro weatherstrip and the vent window action is velvety. I have NOS regulators on both sides....
Old Aug 11, 2017 | 04:56 PM
denson's Avatar
denson
You might want to check the regulator...there is a plate backside and another on the bottom, they are staked into place...if someone tried to crank the regulator handle too hard or if a break-in was attempted, or even if the grease inside gets hard, one of them may pop off and now reside in the bottom of your door. end result you regulator works very poorly...if you can find the plate it can be re-staked into place.
Old Aug 11, 2017 | 05:00 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
Another do not open type here.
To Vent window problem
