Power Steering Leak
Power Steering Leak
I have a terrible leak in my power steering that I can't seem to track down or fix. The power steering pump will be almost dry after about 100 miles. It looks like it's coming from the pressure hose connected to the pump but I have a new hose and new pump and have reinstalled the hose 3 times. I'm fairly confident the threads are not stripped.
I do see some small leaking from there but am stumped with how to fix it. I can't tell if I'm also getting some leaking at the PCV and or the power steering cylinder connections. After I drive it power steering fluid is all over the place.
Any ideas? Thanks.
Any ideas? Thanks.
Any ideas? Thanks.
Any ideas? Thanks.
I prefer to use the UV tracer dye and put it in the fluid and then using the appropriate light I can see where the fluid is coming out due to it somewhat glows.
http://tracerline.com/all-products/f...-and-dyed-oil/
I do not know if an Oreillys or NAPA or some other auto parts store has this tool for loan and you only pay for the small amount of UV dye or not.
DUB
DUB
