Shifter Boot
Old Aug 28, 2017 | 02:46 PM
MarkC's Avatar
MarkC
Veteran: Marine Corps
C2 of Year Finalist (performance mods) 2019
Default Shifter Boot
I have a TKO 5 speed in my 66 and have never been satisfied with the oem rubber boot around the shifter. To get the boot to cover the bolts that hold the shifter handle you have to stretch the boot and it tears with time. The first boot tore after a year or so and now the second boot has torn. I am looking for suggestions like a leather boot on the newer Vettes that will fit a C2 console. Any suggestions?
Old Aug 28, 2017 | 04:17 PM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
Mark
Call me if you have any questions.
https://www.corvetteforum.com/forums...hift-boot.html
To
MarkC's Avatar
MarkC
It looks like there are leather boots made for the C3 and C4 that will work. I may drive up to Zip to look for the best one for my application.
Old Aug 28, 2017 | 04:18 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
The C1s have the same problem and this was my solution:
https://www.corvetteforum.com/forums...post1573120326
A few posts down I show how I dealt with the loose hole at the top of the boot where the shifter exits. NO idea if it'd work on a C2.
Just another option to consider (and its cheap to try)..
Old Aug 28, 2017 | 08:54 PM
buns's Avatar
buns
This is the one I got from Corvette Central, P/N 233036.Fit perfectly with a little adjustment.
Old Aug 29, 2017 | 07:51 AM
MarkC's Avatar
MarkC
Buns, thanks for posting the picture. Right now I am planning a trip to Zip and I can try several there. I am going to take the console out of the car so I can test fit several. It needs to be high enough to cover the two bolts that hold the shifter handle to the trans. I will try yours.
Old Sep 8, 2017 | 12:11 PM
MarkC's Avatar
MarkC
I made my trip to Zip early in the week and Danial was nice enough to pull three boots. No question the 84-85 early boot was the best. I ended up removing the medal frame and it was pretty easy to mount it under the metal frame that holds down the boot boot. I bought a new rubber boot also. I finished it up. This morning. Here are a few pictures.
The hole at the top of the boot is the perfect size to pull up over the shifter handle bolts and the leather is the proper height also. If I can find a leather stitching needle I may take some black thread and close the hole up just a tad. I do not get any warm air up through the hole because I installed a new rubber boot. I am very pleased with the result.
Old Sep 8, 2017 | 01:35 PM
Sky65's Avatar
Sky65
Looks good Marc. I guess I need to get my order in. I'm tired of looking at the rubber boot.
Tom
Old Sep 8, 2017 | 02:01 PM
RatDog's Avatar
RatDog
St. Jude Donor '20 thru '25
Marc - Very nice! I need to replace my rubber boot. I've been looking for a leather replacement but no luck. Is this the one you got from ZIP:
http://www.zip-corvette.com/84-85e-m...fter-boot.html
Thanks,
Steve
Old Sep 8, 2017 | 02:25 PM
68hemi's Avatar
68hemi
C1 of Year Finalist (performance mods) 2019
Yes, but has anyone found anything that will fit tight on the 57 skinny "needle" shifter handle?
Old Sep 8, 2017 | 03:24 PM
65tripleblack's Avatar
65tripleblack
Hi Mark,
Been following this thread with interest, and that boot looks great. When I built my car, the rubber shifter boot was not molded, was somewhat flimsy, and I was able to stretch it over the tops of the mounting bolts for the shifter when I installed the Kiesler 5 speed about 5 years ago.
It finally tore on the bottom corner near the console upper surface, not at the handle area, so I ordered a new rubber boot from LICS. It's different from the boot I installed 18 years ago. It's thicker, and is form-molded with a rectangle molded into it's base at the console level. The old boot didn't have that it was smooth in that area. In any event, this new boot is MUCH nicer than the old boot for a Muncie 4 speed, but will have to be cut to be used with the 5 speed. Using a leather boot over the new rubber boot is a great idea!
Your shifter handle is puzzling. Where is the reverse lockout? Can you post a side view of the shifter because it almost looks like a Hurst handle although the angle might be misleading.
Joe C
Old Sep 8, 2017 | 04:13 PM
MarkC's Avatar
MarkC
Thanks,
Steve
That's it, I got the last one they had in stock but that shouldn't be a problem. Nice quality leather too.
Old Sep 8, 2017 | 04:17 PM
MarkC's Avatar
MarkC
Joe, it's a 6 inch Hurst handle. I also have the fake handle that looks oem but I like the Hurst better.
Old Sep 8, 2017 | 07:08 PM
RatDog's Avatar
RatDog
They must have gotten more in. My order went through OK.
Thanks again,
Steve
To Shifter Boot
